Aller au contenu principal
How will you set up 24 fps in eos m 50
i tried but canon eos m 50 showing ony 25 fps or 60 fps i was not able to adjust on 24 fps
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
3 Réponses
Solution retenue
Hi,
Looking at the user guide it appears as though you have to set the camera up for NTSC 4K or Full HD to get the 24fps.
(Click on images to enlarge for better viewing)
Indice 2
If you're looking to shoot 24p footage, you'll first need to be make sure you're set to NTSC as PAL does not have options for 24p, only 25 and 50p.
Please take some pictures and post them: Ajout d'images à une question existante
Indice 1
Hey I had this problem too. The correct answer is to put the camera into ‘Manual Exposure’ mode from the dial. Click the menu button on the camera and go to function settings. Go the the number 3 on the horizontal menu and ‘Video System’ should be the first option. From there change the mode from PAL to NTSC and when you go back into video mode on the camera you will have the correct frame rates!
Hope that helps.
Indice 1
Ajouter une réponse
John Thelapuram sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 22
Total : 5,176
