BEHOLD, THE MAGIC SOLUTION.
Take some Dental Floss, a Qtip, and GOO GONE.
Position your dental floss behind the battery.
Pull to one side.
Wet the Qtip with Goo Gone generously, hard to get too much.
Pull.
Wet the other side of the floss with Goo Gone.
Pull.
Repeat this process for 30 minutes in this case. You’ll start to feel when that Goo Gone is getting in there nice and good. You sometimes need to use a little bit of force.
WARNING: Do not pour the Goo Gone while the Mac is upside down — remember your LCD Monitor is delicately sitting underneath this all! I saw some pour soul report they melted their screen and had to buy a new Mac. I stood mine up on the side and flossed it. Great technique.
A voté
Annuler
Indice
8
1 commentaire
I personally used the dental floss and prying with a spudger method carefully. Any left over adhesive I used the spudger (plastic one) to scrape off and then used "goof off" to get up the rest. Apply the goof off to a paper towel in small amounts so there's not a ton all over the place. Then work it into adhesive and it'll bring it right up. Then I wiped dry and let it sit 20mins or so to evaporate away and dry. New battery stuck perfectly in. Reassemble.
par Faslane
