Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La manette Xbox One a été introduite en 2016 avec le lancement de la Xbox One S et ajoute la prise en charge du Bluetooth pour Windows 10/11. Cette manette corrige de nombreux défauts de conception présents sur les manettes Modèle 1537/1697 et est beaucoup plus fiable. Cette manette a été remplacée par la manette améliorée Modèle 1914.
What is rattling in my controller?
My son dropped his xbox one Wireless controller and now it makes a rattling sound when it is shaken. What is causing the rattle? Did a small plastic piece break loose inside the controller? Any information will be greatly appreciated… Thanks
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
4 Réponses
Solution retenue
As @zantheproplayz said, it could be a broken stud, but it is also possible it is damage to one of the haptic motors. Chances are it’s harmless, and these controllers are quite easy to get apart as well.
Good luck!
EDIT: Follow this guide and once you get the faceplate off, shake it around a bit, and see if anything comes out. That will stop the rattling if it is in fact a broken plastic piece.
Indice 2
2 commentaires:
This did not work for me. the rattle in my elite v2 controller is not coming from any broken part. The rattle only happens when the motors spin fast, i think they are loose. I have as of yet to come up with a solution as there seems to be no good teardown of the v2 elite controller, so im not sure how to take it apart. Im going to give it a try and assuming i get it back together, ill make a guide on it.
par
So if my left bumper above the trigger feels loose do I have to worry about it?
par
Réponse la plus utile
Hi!
I have this problem once and if the controller is working, nothing to worry about. its just a piece of plastic or a piece of a stud broken off lose and mke the rattling noise.
Hope this Helps
Indice 4
I reccomend removing that batteries inside and continuously shake it, while upside down, to remove the loose piece
Indice 2
3 commentaires:
This worked for me, thanks!
par
It gets stuck between the circuits
par
Let me try first and tysm
Indice 0
1 commentaire:
No I tried that multiple times and it keeps getting stuck between the circuits
par
Ajouter une réponse
Dustin Baker sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 27
30 derniers jours : 124
Total : 33,902
