Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,4 GHz, 2,7 GHz ou 2,8 GHz (Turbo Boost jusqu'à 3,8 GHz) avec 6 Mo de cache L3 partagé.
20 questions Voir tout
MBP Stopped Charging, No Mag Light
Just today, our MacBook Pro (15” Early 2013) stopped charging. I have tried two Apple Magsafe 2 power supplies with the same result. Neither lights up on the power supply connector, and there is no charging indication for the battery in MacOS.
For the last year or so, the battery has reported “Service Soon” or something similar. It doesn’t last long and is probably on it’s last leg.
Is the charging issue related to the battery or is this associated with internal electrical hardware?
Is the logic board responsible for the Magsafe operation and battery charging, or is there another electrical assembly that does this? I’m wondering what should be replaced - logic board, battery, or something else?
Below is an screenshot from coconutBattery.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
If the battery tells charging ic that its not safe to get charhed then sequence getting stopped. Try battery replacement first and then if its same thing post your logic board number
Indice 0
hello,
do you see green light all the time and won’t turn into red ?
Indice 0
Ajouter une réponse
Jimmy M sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 76
