Aller au contenu principal
La manette Nintendo GameCube DOL-003. Sortie en novembre 2001, compatible avec la Nintendo GameCube, la Nintendo Wii, la Nintendo Wii U et la Nintendo Switch. La réparation de cet appareil est simple et ne nécessite que des outils courants.
Left joystick is pulling to the right
My left stick pulls to the right, not consistent strength and not consistently all the time. I have tried a button reset (start, x, y) but that does not work. Any suggestions on how I can fix it w/out putting in a whole new stickbox?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
@discardedcouch sound like a worn out analog joystick (weakened springs most commonly). Not much you can do but to consider replacing the joystick. This Remplacement du joystick du Nintendo GameCube Controller would get you where you would need to be to solder a new stuck in place.
Indice 2
Same things is happening to me, I bought a new TV and my Gamecube controller (an original one) started tilted to the right often when I pull left… it looks alright and centered on the controller but for example on Smash Ultimate menu or character selection, it often goes back to right when I want to go left… I managed to play online for an hour and then it happened again… I don’t think the TV or even the GC adapter is faulty cause my other Gamecube controllers are working fine for the moment. So it’s a spring problem ? Weird that if happened so suddenly, I mean two days ago it was fine… but I think I’m gonna try to open the controller to see.
Indice 0
Ajouter une réponse
Discarded Couch sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 4,394
