Aller au contenu principal
This iteration of Amazon's Kindle Paperwhite series was released on June 30, 2015. The Kindle Paperwhite 3rd Generation is a 6-inch, 300 PPI reading display tablet that is Wi-Fi capable. The designated model number is DP75SDI.
Kindle Replacing USB socket by bypass inside
Hi,
I started replacing the USB socket in my Kindle but accidentally the conductor strips were thorn.
Now, I want to do a bypass and solder it directly to the right spot using thin wires.
The problem is that I can't determine where to solder them.
Could you advice me where to solder all 4 pins?
Thank you,
Erez
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
You see the light coloured lines that lead to where the pads were. Scrape them until you see the copper trace then solder from there.
Indice 1
Old post lol. Clean the board and follow the traces. Might help someone else with a similar issue.
Indice 1
Ajouter une réponse
Erez Lahav sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 164
