Aller au contenu principal
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 questions Voir tout
No service engine soon light at all.
Service engine soon light is not coming on during test cycle? Is there a fuse for this light?
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Tiny dashboard lights don’t typically have their own fuses since they are fed from other sources such as the ECU on modern cars. I would attempt to check the bulb and see if it has failed. You need a full wiring diagram for your vehicle if you want to solve this. A good dealership tech is probably going to give you better advice than you can likely find here. Reading the codes from the ECU might tell you what is wrong easily.
Indice 0
Ajouter une réponse
Reece Rongey sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 397
