Aller au contenu principal
Repair guides and support for televisions manufactured by Panasonic.
Panasonic TX-L47ETW5 does not start after standby
A friendly hello to everyone,
we have a technical problem with our Panasonic LCD TV and need your help.
I've read a number of helpful posts on the Internet and here in the forum, but unfortunately I couldn't find a comparable post.
The error only appeared occasionally a few weeks ago, now with almost every switch-on from standby (red LED on).
The device is connected to the mains via a switchable socket strip. If it is now switched off and disconnected from the mains via the power strip for a few hours, the device only occasionally starts correctly from standby.
Normal behavior after switching on the power strip:
- green LED flashes for approx. 5 seconds, the backlight comes on, the green LED lights up continuously and after 5 seconds there is picture/sound.
or:
- The red LED LED lights up and the device can be started from standby using the power button on the remote control or on the device itself.
The device then runs for several hours without any problems.
Error:
TV is switched off via the remote control in standby (red LED lights up, power strip remains on).
If the device is now switched on again via the remote control or the switch on the side of the TV, the green LED flashes for approx. 5 seconds.
the backlight does not come on (green LED lights up continuously) and after another 5 seconds no picture/sound either. The green LED lights up continues permanently as in normal operation.
This error occurs regardless of whether, for example, other devices are connected.
The following parts are installed in the TV:
- Panel: LG LC470EUD (SE)(FE)
- LCD driver: LG KLS-E470DRGHF12 B Rev 0.2
- PSU: TNP A5608 2P TXN/P10TWUB
- Motherboard: TNP H0993 1A TXN/A10TYUE
- T-Con: TNP A5587 1FR
Previous troubleshooting and findings:
- Operating hours according to the service menu approx. 17,000 with 14,000 on/off operations
- Software update via SD card not possible, since the current 1.269 is installed
- Checked all circuit boards with a microscope for cold solder joints or abnormal components, no abnormalities found
- no reaction to cold spray or heat on all boards in working condition as well as with error
- Various service manuals for similar devices were unfortunately not helpful, especially since the LG components were also missing
- Self-Check does not bring any errors, but can only be started if the backlight and image are also active
- LVDS cable to T-Con disconnected: error still occurs
- no blink codes (red LED)
further considerations:
- I did not want to heat (reflow) the IC8000 BGA for the time being on suspicion, since replacement mainboards are currently available
- I don't want to remove the panel on suspicion to check the individual LEDs
- I haven't found a way to reinstall the software yet
What could that be?
Thanks in advance for any tip!
Greetings Marc
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Solution retenue
Hi @mbtec,
What happens if you connect the TV directly to a mains outlet and not via the powerstrip?
The firmware can be downloaded to an SD card and then reinstalled on a new A board but I'm not sure if this works if trying to install it back on the same board.
With other Panasonics I've worked on you can only upgrade the firmware with a later version and not using the same version as is already installed. Also the upgrade file may not be the full firmware file, only an update to overcome a known problem etc.
Here's the service manual that may help. See p.13 Self Check and perhaps p.17 Service Tool Mode > Display of SOS History although this may be more applicable to a red standby light flashing which it isn't.
Indice 2
9 commentaires:
Hi @jayeff
Thank you very much for the manual and the quick feedback! I will work through the manual.
Yes, upgrade the firmware is only with a later version as the same version possible yet. I dont't know, if there is any possibility to do this in another way than SD-Card. The upgrade file from Panasonic ist about 80 MB. Like you said, this might be only an update and not full firmware.
Same error when TV is directly connected to a mains outlet.
But now:
TV is directly connected to a mains outlet and started without error. After a few minutes I switched TV off via the remote control in standby (green LED goes off and red LED lights up). If I try to power on TV now:
- via the remote control: red LED blinks when a key is pressed on remote control, no green LED, no backlight or picture/sound
- via power button on side of TV: no reaction, only after 5 sec. holding power buttton the red LED goes off and lights up again
self check etc. not possible
TV disconnected from main and after 10 min. it started normal, self check ok, I can upload picture if this may help. After power off via remote control same error as in my first post :-(
Hope You have any idea?
par
@jayeff
do you know where I can get the "LCD TV Technical Guide/Training" for ETW5 series?
par
@mbtec
You said " via the remote control: red LED blinks when a key is pressed on remote control, no green LED, no backlight or picture/sound"
Count the number of times it blinks and then look at the Power LED blinking timing chart on p.14 of the service manual.
No idea about the training guide. I was lucky to find the service manual
par
@jayeff
ok, i am very happy about the service manual you found! Thanks a lot.
There are unfortunately no number of counts, the red LED only blinks "fast" as long a key on remote control is pressed (feedback?)
I test it again and check if the the number of times are always the same or different. Thanks
par
@jayeff
Hi,
red LED only blinks when a key on remote control ist pressed
I'm working through the manual, here are the first results:
Error: green LED light, no backlight or picture/sound
red LED no light or blink
STB5V 5V
P15V 16V
24 V für LED-Treiber
TV_SUB_ON 2,4V
BL_on 0V
BL_PWM 0V
BL_SOS 0V
TV running normal:
BL_ON 3,2 V
BL_PWM 1,5 V
BL_SOS 0V
par
Voir 4 commentaires en plus
Ajouter une réponse
MB-Tec sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 7
Total : 300
