Keyboard Backlight OFF when Camera Connected or after sleep
I deleted the previous 2 questions as this issue is obviously related to each other and was getting a little confusing so here we go....
MacBook Air A1465 11" 2014 (Big Sur 11.7.10) Recent fresh install.
SMC & PRAM resets have been done and Coconut Battery reports good normal battery health tested with 2 good batteries and there are no issues found in Apple diagnostics.
Original Issue: Camera was not working & 4 or 5 faulty Keyboard keys.
Replaced Keyboard (ALL keys are now working fine) & Antenna Assembly.
Camera is detected in system report hardware list.
All the ******connections are seated correctly, there are no damaged cables or connectors. There has not been any water damage, internally a very clean unit. All the parts used are fully compatible with this model of MB Air so there are no issues with compatibility.
Booting with the camera connected I have only a flashing green light on the camera (No picture) and I have no KB Backlight after closing photo booth or display brightness was automatically adjusting to very low at boot unchecked box and checked no difference was noticed. I then replaced the antenna with another.
Booting with no camera connected the KB Backlight is stable and working normally at all times.
As stated previously I changed the antenna assembly with one that had broken off WiFi connectors which we successfully have reconnected and the WiFi & Bluetooth functions as intended (the 1st replacement obviously had an issue somewhere and has now been returned for a replacement) and now the camera is working fine but there is no keyboard backlight at any time and the KB keys to adjust the BL are blocked out.
I have tried with 3 different known working camera units and other new TP cables but no difference was achieved in the outcome.
It is either a working camera and no keyboard backlight or a working keyboard backlight and no camera. Answers on a postcard please :D @oldturkey03 & @danj Also as a footnote boot time from power up is a bit 'delayed' maybe 6-8 seconds & the camera when it is working is quite bright with no deep colors, like the brightness is up, but there are no options to adjust the camera levels that I am aware of?
