Aller au contenu principal
ASUS Chromebook C424MA-DH48F Battery Replacement
Anthony Wink
Anthony Wink et 2 autres contributeurs
Dernière mise à jour le December 19, 2024
10 - 15 minutes
Facile
Tutoriel étudiant vedette
This is the ASUS Chromebook (Model C424MA-DH48F), here we will be guiding you though a full battery replacement for the ASUS Chromebook.
Reasons to replace the battery include:
  • Overheating
  • Reduced battery life
  • Slow charging
  • Swollen battery
  • Laptop dying unexpectedly
After replacing the component if you plan on disposing of the old battery here is a link explaining proper battery disposal.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. ASUS Chromebook C424MA-DH48F Battery Replacement, Lower Case: étape 1, image 1 de 2 ASUS Chromebook C424MA-DH48F Battery Replacement, Lower Case: étape 1, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the eleven 6.9 mm screws that secure the lower case.
    • Make sure all the screws on this side get taken out because there could be a label or warranty sticker covering up a screw that might be missed.
    • Insert an opening pick into the gap between the lower case and chassis.
    • Slide the pick around the entire perimeter of the laptop until the lower case fully releases.
    • Remove the lower case.
  2. ASUS Chromebook C424MA-DH48F Battery Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: étape 2, image 1 de 3 ASUS Chromebook C424MA-DH48F Battery Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: étape 2, image 2 de 3 ASUS Chromebook C424MA-DH48F Battery Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: étape 2, image 3 de 3
    • Use an opening tool to pop up the silver locking bar securing the battery connector.
    • Push the battery connector directly out of its motherboard port.
  3. ASUS Chromebook C424MA-DH48F Battery Replacement, Battery: étape 3, image 1 de 3 ASUS Chromebook C424MA-DH48F Battery Replacement, Battery: étape 3, image 2 de 3 ASUS Chromebook C424MA-DH48F Battery Replacement, Battery: étape 3, image 3 de 3
    • Carefully use the plastic prying tool and pop up the locking bar and lift the connector off with your hand.
  4. ASUS Chromebook C424MA-DH48F Battery Replacement: étape 4, image 1 de 3 ASUS Chromebook C424MA-DH48F Battery Replacement: étape 4, image 2 de 3 ASUS Chromebook C424MA-DH48F Battery Replacement: étape 4, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the six 4.1 mm screws that secure the battery.
    • The two screw holes (marked in orange) on the bottom won't have screws associated with them since they were removed earlier when the base was removed.
    • Unseat the speaker cable from the black plastic hooks on the lower side of the battery.
    • Lift the battery up and out of the chassis.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Anthony Wink
Membre depuis le 08/28/24
401 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 16
Total : 83
