Aller au contenu principal
ASUS Q400A-BHI7N03 RAM Replacement
Matthew Gold
Matthew Gold et 8 autres contributeurs
Dernière mise à jour le January 3, 2024
15 - 30 minutes
Modérée
Photos d’action
If your ASUS Q400A-BHI7N03 laptop has been struggling to keep up with your demands, experiencing sluggish performance and lag when running applications,use this guide to replace its RAM (Random Access Memory). The RAM plays a critical role in your laptop's performance. An insufficient or faulty RAM module can lead to slow operation, unresponsive programs, and decreased productivity. In this guide, we will take you through a step-by-step process to replace the RAM in your ASUS Q400A-BHI7N03 laptop, Before we start the process, inspect your laptop for any potential issues and make sure to turn it off completely and disconnect it from any external power sources.
Ce dont vous avez besoin
Outils
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. ASUS Q400A-BHI7N03 RAM Replacement, Battery: étape 1, image 1 de 1
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop over so that it is upside down.
    • The slightly raised area is the battery.
    • Orient the laptop so that the battery is away from you.
  2. ASUS Q400A-BHI7N03 RAM Replacement: étape 2, image 1 de 1
    • In the top right corner, push the tab to the right to the unlocked position.
  3. ASUS Q400A-BHI7N03 RAM Replacement: étape 3, image 1 de 2 ASUS Q400A-BHI7N03 RAM Replacement: étape 3, image 2 de 2
    • Find the tab in the top left corner. With one finger, pull the tab to the left to the unlocked position.
    • While holding this tab in the unlocked position, gently pull the battery away from you.
    Maybe add a reminder to lock the battery back in that was unlocked in Step 2.
    Kevin Low - Réponse
  4. ASUS Q400A-BHI7N03 RAM Replacement, RAM: étape 4, image 1 de 1
    • Flip the laptop so that it is upside down and locate a screw near the middle of the laptop. Remove the 8 mm PH0 screw.
  5. ASUS Q400A-BHI7N03 RAM Replacement: étape 5, image 1 de 2 ASUS Q400A-BHI7N03 RAM Replacement: étape 5, image 2 de 2
    • Use a spudger or opening tool to remove the L shaped section of the back cover.
    • To avoid breaking the plastic, alternate the sides where you pry.
  6. ASUS Q400A-BHI7N03 RAM Replacement: étape 6, image 1 de 3 ASUS Q400A-BHI7N03 RAM Replacement: étape 6, image 2 de 3 ASUS Q400A-BHI7N03 RAM Replacement: étape 6, image 3 de 3
    • The RAM is located in the top of the section you uncovered.
    • Identify the two metal tabs on both sides of the RAM.
    • Gently push both tabs outwards at the same time. The RAM will pop up.
    • Carefully pull the RAM out.
    Mention that there are 2 RAM modules that can be replaced.
    Jaspal Chauhan - Réponse
  7. ASUS Q400A-BHI7N03 RAM Replacement: étape 7, image 1 de 2 ASUS Q400A-BHI7N03 RAM Replacement: étape 7, image 2 de 2
    • To put RAM back in, lineup the RAM with the plastic holder.
    • Slide it into the slot at a 30 degree angle and push down until it clicks into place.
Matthew Gold
Membre depuis le 01/19/17
401 Réputation
4 tutoriels rédigés
Équipe
UC Davis, Team 1-4, Rodger Winter 2017 Membre de l'équipe UC Davis, Team 1-4, Rodger Winter 2017
UCD-RODGER-W17S1G4
5 membres
4 tutoriels rédigés
2 commentaires de tutoriel
Hello there ! I got a question. What type of ram should I buy to replace my Asus ? I trying to upgrade to 16 gb
rockygc1985 - Réponse
If I only have 1 stick of 4gb, and assuming I won't be getting more, does it matter which slot I place it? Top or bottom (closer to the motherboard) ? Thanks ahead of time!
John H - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 4
Total : 757
