Aller au contenu principal
Acer Aspire V5-572, V5-572G HDD Replacement
ZFix
ZFix et 3 autres contributeurs
Dernière mise à jour le October 31, 2023
5 - 10 minutes
Facile
Tutoriel réalisé par la communauté
Acer Aspire - V5-572, V5-572G
Follow this guide if you want to change / upgrade your HDD (Hard Disk Drive) or install SSD (Solid State Drive).
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
Vidéo d'introduction
  1. Acer Aspire V5-572, V5-572G HDD Replacement, Bottom Cover: étape 1, image 1 de 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G HDD Replacement: étape 2, image 1 de 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G HDD Replacement: étape 3, image 1 de 3 Acer Aspire V5-572, V5-572G HDD Replacement: étape 3, image 2 de 3 Acer Aspire V5-572, V5-572G HDD Replacement: étape 3, image 3 de 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
    Love the tutorial man...but this is the most moronic thing I've ever seen...you can take batery out of laptop 15 years old in a flash, while here you have to disassemble the whole %#*@ laptop...only idiots can come up with something like that
    razbojnikkuro - Réponse
    I have to agree that this is extremely complicated and intense.
    There is no way your average user should be doing this and the average user should be able to replace the battery!!
    Like everything in the computer world, hardware or software, ease of use is no longer even a consideration!!
    Technical Support Bots are the rule and they rarely are up to date with the pages on the website!!
    Sucks!!
    andy.cox - Réponse
  4. Acer Aspire V5-572, V5-572G HDD Replacement: étape 4, image 1 de 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G HDD Replacement, HDD: étape 5, image 1 de 3 Acer Aspire V5-572, V5-572G HDD Replacement, HDD: étape 5, image 2 de 3 Acer Aspire V5-572, V5-572G HDD Replacement, HDD: étape 5, image 3 de 3
    • Disconnect the SATA Cable from the Mother Board.
    • Take out the HDD and remove the SATA cable from it.
    • Now you can change / upgrade your HDD.
3 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
194 352 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
326 membres
1 687 tutoriels rédigés
7 commentaires de tutoriel
Thank you very much for the tutorial, it was a 12 minute job ☺️And extremely pleased with the new ssd its incredible
Best Regards
Luckystyx - Réponse
Thank you so much for the extremely easy tutorial and it definitely only took 2 minutes longer (12 minutes)
Your site is invaluable, Keep up the great work and all that you do,
5 star rating for you guys..
Kindest Regards
@Styx
Luckystyx - Réponse
So the original hdd came in with the win 7 and it was later upgraded to win 10 for free. If i change it to ssd would i be able to get on it my original copy of win 7 and will it upgrade to win 10?
ashmir - Réponse
ashmir, you just clone your HDD with a free software such as Macrium Reflect and don’t need to worry about installing everything from zero!!!
Miguel Rodríguez - Réponse
Thank you for the tutorial.
But need a clarification. If i have a faulty hard disc it starts up but it freezes after 20 minutes.
Is it still possible to clone it.
Also if i change the hard drive do I need to install any software or the bios all over again.
Your inputs will be appreciated.
olatunji.jimoh - Réponse
I haven’t had much luck cloning hard drives that already showed signs of failure, but it costs nothing to try. Download something like Macrium Reflect (free version) and plug the new drive into an external enclosure, and see if it will clone successfully.
Jeff Suovanen -
Can i add ssd and keep my hard drive?
Please somebody answer my question!
Saeid Heydari - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 18
30 derniers jours : 71
Total : 18,746
