Anbernic RG35XX Battery Replacement
Introduction
Passez à l'étape 1The battery supplies power to the device that allows hours of playtime. If the battery isn't turning on, use the Anbernic_RG35XX_Screen_Glitch guide to determine the possible issues. This guide shows how to replace the battery.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
Remove the SD card located on the right side of the device by pushing into the SD card slot and pulling the card out.
Remove the six 1.2 mm screws that secure the back case with a 2.5 Hex Bit screwdriver.
Use your fingernails or tweezers to gently remove the battery connector from its socket.
Use a spudger to gently pry around the perimeter of the battery until it releases.
Remove the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
