Aller au contenu principal
Anker SoundCore mini disassembly
Sebastian
Sebastian et 3 autres contributeurs
Dernière mise à jour le March 5, 2024
30 minutes - 1 heure
Facile
Tutoriel réalisé par la communauté
This guide describes how to disassemble and reassemble the Anker SoundCore mini bluetooth box. Once disassembled, single parts can be exchanged / repaired easily.
  1. Anker SoundCore mini disassembly, Casing opening: étape 1, image 1 de 3 Anker SoundCore mini disassembly, Casing opening: étape 1, image 2 de 3 Anker SoundCore mini disassembly, Casing opening: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    • Carefully remove the rubber cover (glued) from the base.
    • Remove the 3 screws using a screwdriver.
    • Pull the lower part carefully to open the casing.
    • You may use a slotted screwdriver, plastic card etc. along the slit to open as the cables are fixed with sealing paste inside.
    • When the slit opened, remove
    • the red battery cable plug and the white speaker cable plug (red arrows) from the socket by pulling and
    • the volume/play control cable by pulling the black lash (green arrow) upward and pulling the cable out of the socket
    • to separate the lower (PCB) part from the speaker & battery part.
    You can feel the depressions where the 3 screws are, then if you pull back the rubber just where necessary you can remove the screws while leaving the rubber in place.
    Mark - Réponse
    Similarly, I just penetrated the rubber with the screwdriver in the locations of the screws. Won’t notice a slightly ripped up rubber foot, but might well notice if it’s loose or gone completely.
    Ash - Réponse
    Careful with pulling the plugs as the plastic slots can come off. They’re basically just held in place with a funny blob of glue. Not the end of the world if it does as I imagine you can fix them back into place, but definitely nicer to avoid!
    Ash - Réponse
    I found 2 points here that occured to me.. When pulling the lower part.. the inner plastic core of the entire speaker came down from the outer aluminum housing.. I found that the only thing holding that in beyond a little friction was the rubber covering of the volume and play buttons.. Not sure what if anything was supposed to prevent this.
    Also the lower part took quite a bit of force for me to remove. Dont be agressive, but apply constant force for some time and you will see it slowly seperate. Using a plastic card seemed to help for me, "plastic card here was an old phone protector plastic film that i keep around for exactly this. After i see a gap, i used a small screwdriver to lever the rest of it loose rather than pulling, so I dont risk pulling at the cables.
    ktaragorn - Réponse
    Mark, Ash, and ktaragorn--thanks so much for your input. I'm about to start disassembling mine, so each of your comments was valuable to me.
    zuzubird - Réponse
  2. Anker SoundCore mini disassembly, Main PCB removal: étape 2, image 1 de 1
    • Remove the 4 screws using a screwdriver and take off the PCB from the lower casing.
    • Note: The On/Off switch cover is neither fixed in the casing nor on the PCB. When remounting, pay attention to the correct positioning of the switch cover.
  3. Anker SoundCore mini disassembly, Speaker / battery part opening: étape 3, image 1 de 2 Anker SoundCore mini disassembly, Speaker / battery part opening: étape 3, image 2 de 2
    • Remove the 4 screws using a screwdriver.
    • Remove the inner separation from the casing by pulling, starting at the opposite side of the volume/play switch cable.
    • Be careful as the volume/play switch cable is still fixed on the other side, so the separation cannot be removed without removing the connector on the other side.
    • You may use a slitted screwdriver, plastic card etc. to push at the lashes (green arrows).
    I had four screws here, not three. Not sure if I have a different revision.
    Edit: nope, I can see the fourth one in the picture too, it’s very dark though - you will need to really zoom in/boost your brightness/etc to see it.
    Ash - Réponse
    This construction is really very unfriendly to repair.. I didnt want to risk removing the connector for the volume cable as I couldnt see how I can install it again without removing all the glue holding it in place in both parts of the housing. I was able to get to and remove the battery without bothering though.
    ktaragorn - Réponse
  4. Anker SoundCore mini disassembly, Battery removal: étape 4, image 1 de 1
    • Remove the battery pack carefully by pulling it upward (it is fixed by glue only to the speaker casing).
    Surprisingly strong glue but it will work again when you reverse it.
    Mark - Réponse
    Does anyone know if it is possible to buy a replacement battery ? I have searched far and wide and cant find one.
    Failing that can someone give me the approximate dimensions of the battery and connector type so I can search for a generic one ( I assume it is Lithium Ion 3.7V
    Peter Mathews - Réponse
    I find AliExpress is the place to go for replacement batteries, just keep searching away, plugging in the relevant dimensions. Typically, 3.7v is the voltage but connectors may be a problem. You may have to recycle the original ones, soldering them onto the new battery. What I recommend is first disassembling the unit and extracting the battery; only then start searching for a replacement battery. That way if you botch the disassembly you won't get stuck with an orphaned battery.
    Luca -
    Battery markings indicate that it is a PT103450 6.6 WH, 1800 mah, though this seems to be a lie.. it is a 4cm by 4cm square and 1cm thick, which makes the correct marking 104040, not sure why this is different.
    ktaragorn - Réponse
    The listing might expire but https://www.aliexpress.com/item/40010850... seems like a good option for a spare.
    ktaragorn - Réponse
  5. Anker SoundCore mini disassembly, Speaker removal: étape 5, image 1 de 2 Anker SoundCore mini disassembly, Speaker removal: étape 5, image 2 de 2
    • Remove the volume/play switch cable by pulling the black lash (green arrow) outward, then pulling out the connector from the socket. Remove the inner separation and the volume/play switch cable linked with it.
    • Remove the 2 screws using a screwdriver and remove the speaker.
  6. Anker SoundCore mini disassembly, Volume/play switch removal: étape 6, image 1 de 2 Anker SoundCore mini disassembly, Volume/play switch removal: étape 6, image 2 de 2
    • Remove the volume/play switch rubber cover (green arrow).
    • Remove the 2 screws using a screwdriver.
    • Pull out the volume/play switch control panel from the inner side of the casing.
    Can't pull out the volume/play switch control panel from the inner side of the casing. Because the casing has 2 side, that cover up the volume/play switch control panel from the inner side of the casing.
    Romi Oktavian - Réponse
When reassembling, pay attention
  • to correctly insert all connectors into their sockets
  • to the right positioning of the speaker and battery cables when pulling them through the inner separation (and reconnecting them to the PCB)
  • to correctly position the On/Off switch cover when remounting the PCB.
To ensure a similar sound quality as before, the cable entries in the inner separation may need sealing after the cables have been reconnected. If this becomes necessary, hot glue or some sealing paste/wax could be used for this.
14 autres ont terminé cette réparation.
Sebastian
Membre depuis le 07/26/20
976 Réputation
3 tutoriels rédigés
10 commentaires de tutoriel
Much appreciated when some cleaning stuff got spilt through the vents on the top onto the speaker and needed to get it out to clean up the mess. thanks
Mark - Réponse
Re- the On/Off button - the article talks about getting it in the right position, but the right place seems to be missing. The red goes on the right.
Currently got mine in pieces waiting for it to dry out after it fell in the bath. Fingers crossed as it did seem to work still, just that you also got to hear the Bluetooth module along with your sound!
Ash - Réponse
What kind of battery does this unit use? Ours won’t hold a charge anymore, and if it takes an easily obtained battery type, I’d gladly open it up and replace it.
JWosnick - Réponse
1800mah 3.7v 6.7wh li-po battery. Not sure if the li-po batteries are too big when they're that size, as Anker produce their own batteries. I've bought a li-po, so I'll report back with info.
Leanne -
I have the same problem. Would love to hear if li-po worked!
Birgitta Berger -
Replied above, copying here:
ktaragorn -
Hello, for some reason the speaker popped and I checked the rubber around it and it's fine. The speaker has only been used for 2 months and wanted to precise a replacement speaker part. Could you please tell me what size speaker or part number I need to purchase?
Jorge Gamez - Réponse
Does anybody know whether I can remove the battery entirely, reassemble (with no battery) and power the speaker by keeping it plugged into a USB supply?
I have one of these where the battery is dead, but I don't need the battery. If I could power it via USB, but without the battery (to avoid the unnecessary risk of the battery ballooning/catching fire) that would be great.
Pete - Réponse
Did you find a Solution for this case?
Juan -
Hello , B2 element near Micro USB port of soundcore mini a3101 was burned . do you know what is that element? is there any repair manual of this gadget ?
Reza - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 43
30 derniers jours : 199
Total : 16,283
