Anker SoundCore mini disassembly
Introduction
Passez à l'étape 1This guide describes how to disassemble and reassemble the Anker SoundCore mini bluetooth box. Once disassembled, single parts can be exchanged / repaired easily.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Plastic Cards$2.99
Carefully remove the rubber cover (glued) from the base.
Remove the 3 screws using a screwdriver.
Pull the lower part carefully to open the casing.
You may use a slotted screwdriver, plastic card etc. along the slit to open as the cables are fixed with sealing paste inside.
When the slit opened, remove
the red battery cable plug and the white speaker cable plug (red arrows) from the socket by pulling and
the volume/play control cable by pulling the black lash (green arrow) upward and pulling the cable out of the socket
to separate the lower (PCB) part from the speaker & battery part.
Remove the 4 screws using a screwdriver and take off the PCB from the lower casing.
Note: The On/Off switch cover is neither fixed in the casing nor on the PCB. When remounting, pay attention to the correct positioning of the switch cover.
Remove the 4 screws using a screwdriver.
Remove the inner separation from the casing by pulling, starting at the opposite side of the volume/play switch cable.
Be careful as the volume/play switch cable is still fixed on the other side, so the separation cannot be removed without removing the connector on the other side.
You may use a slitted screwdriver, plastic card etc. to push at the lashes (green arrows).
This construction is really very unfriendly to repair.. I didnt want to risk removing the connector for the volume cable as I couldnt see how I can install it again without removing all the glue holding it in place in both parts of the housing. I was able to get to and remove the battery without bothering though.
Remove the battery pack carefully by pulling it upward (it is fixed by glue only to the speaker casing).
Does anyone know if it is possible to buy a replacement battery ? I have searched far and wide and cant find one.
Failing that can someone give me the approximate dimensions of the battery and connector type so I can search for a generic one ( I assume it is Lithium Ion 3.7V
I find AliExpress is the place to go for replacement batteries, just keep searching away, plugging in the relevant dimensions. Typically, 3.7v is the voltage but connectors may be a problem. You may have to recycle the original ones, soldering them onto the new battery. What I recommend is first disassembling the unit and extracting the battery; only then start searching for a replacement battery. That way if you botch the disassembly you won't get stuck with an orphaned battery.
Luca -
The listing might expire but https://www.aliexpress.com/item/40010850... seems like a good option for a spare.
Remove the volume/play switch cable by pulling the black lash (green arrow) outward, then pulling out the connector from the socket. Remove the inner separation and the volume/play switch cable linked with it.
Remove the 2 screws using a screwdriver and remove the speaker.
Remove the volume/play switch rubber cover (green arrow).
Remove the 2 screws using a screwdriver.
Pull out the volume/play switch control panel from the inner side of the casing.
Can't pull out the volume/play switch control panel from the inner side of the casing. Because the casing has 2 side, that cover up the volume/play switch control panel from the inner side of the casing.
When reassembling, pay attention
- to correctly insert all connectors into their sockets
- to the right positioning of the speaker and battery cables when pulling them through the inner separation (and reconnecting them to the PCB)
- to correctly position the On/Off switch cover when remounting the PCB.
To ensure a similar sound quality as before, the cable entries in the inner separation may need sealing after the cables have been reconnected. If this becomes necessary, hot glue or some sealing paste/wax could be used for this.
14 autres ont terminé cette réparation.
10 commentaires de tutoriel
Re- the On/Off button - the article talks about getting it in the right position, but the right place seems to be missing. The red goes on the right.
Currently got mine in pieces waiting for it to dry out after it fell in the bath. Fingers crossed as it did seem to work still, just that you also got to hear the Bluetooth module along with your sound!
What kind of battery does this unit use? Ours won’t hold a charge anymore, and if it takes an easily obtained battery type, I’d gladly open it up and replace it.
1800mah 3.7v 6.7wh li-po battery. Not sure if the li-po batteries are too big when they're that size, as Anker produce their own batteries. I've bought a li-po, so I'll report back with info.
Leanne -
I have the same problem. Would love to hear if li-po worked!
Replied above, copying here:
Battery markings indicate that it is a PT103450 6.6 WH, 1800 mah, though this seems to be a lie.. it is a 4cm by 4cm square and 1cm thick, which makes the correct marking 104040, not sure why this is different.
Hello, for some reason the speaker popped and I checked the rubber around it and it's fine. The speaker has only been used for 2 months and wanted to precise a replacement speaker part. Could you please tell me what size speaker or part number I need to purchase?
Does anybody know whether I can remove the battery entirely, reassemble (with no battery) and power the speaker by keeping it plugged into a USB supply?
I have one of these where the battery is dead, but I don't need the battery. If I could power it via USB, but without the battery (to avoid the unnecessary risk of the battery ballooning/catching fire) that would be great.
Did you find a Solution for this case?
Juan -
You can feel the depressions where the 3 screws are, then if you pull back the rubber just where necessary you can remove the screws while leaving the rubber in place.
Mark - Réponse
Similarly, I just penetrated the rubber with the screwdriver in the locations of the screws. Won’t notice a slightly ripped up rubber foot, but might well notice if it’s loose or gone completely.
Ash - Réponse
Careful with pulling the plugs as the plastic slots can come off. They’re basically just held in place with a funny blob of glue. Not the end of the world if it does as I imagine you can fix them back into place, but definitely nicer to avoid!
Ash - Réponse
I found 2 points here that occured to me.. When pulling the lower part.. the inner plastic core of the entire speaker came down from the outer aluminum housing.. I found that the only thing holding that in beyond a little friction was the rubber covering of the volume and play buttons.. Not sure what if anything was supposed to prevent this.
Also the lower part took quite a bit of force for me to remove. Dont be agressive, but apply constant force for some time and you will see it slowly seperate. Using a plastic card seemed to help for me, "plastic card here was an old phone protector plastic film that i keep around for exactly this. After i see a gap, i used a small screwdriver to lever the rest of it loose rather than pulling, so I dont risk pulling at the cables.
ktaragorn - Réponse
Mark, Ash, and ktaragorn--thanks so much for your input. I'm about to start disassembling mine, so each of your comments was valuable to me.
zuzubird - Réponse
