Aller au contenu principal
Apple Powerbook 5300 Hard Drive Replacement
Scott
Scott et 15 autres contributeurs
Dernière mise à jour le May 20, 2022
35 - 55 minutes
Modérée
Photos d’action
Détails manquants
This set of instructions covers the Apple Powerbook 190/5300 Series’ hard drive removal and replacement.. This procedure should be performed for the replacement of a faulty or inoperable hard drive; including but not limited to data cable damage, or power cable damage. The user may also want to remove their hard drive to secure their data from compromise.
This device contains the highest voltage of any Powerbook of its time, and requires precaution. Remove the battery and power adaptor before the procedure.
Ce dont vous avez besoin
Outils
  1. Apple Powerbook 5300 Hard Drive Replacement, Battery: étape 1, image 1 de 2 Apple Powerbook 5300 Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • To begin this repair process first position the Powerbook towards you with the monitor closed, also make sure the laptop is away from anything that can cause a fire, self harm, etc.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out. Make sure you place the battery in a safe place where it can also be easily accesible
    • ALSO NOTE: The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
  2. Apple Powerbook 5300 Hard Drive Replacement, Keyboard: étape 2, image 1 de 1
    • For the next step you are to grab the TR8 Torx Security Screwdriver
    • Once you have the screwdriver turn the laptop over and look for three T8 torx screws that should be located near the bottom panel of the device.
    • Once located, begin unscrewing and place screws in a comfortable space where they are easily accesible
  3. Apple Powerbook 5300 Hard Drive Replacement: étape 3, image 1 de 1
    • Once the screws are off carefully turn the laptop over, make sure the monitor of the device is facing you
    • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
    • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use the spudger tool to lift the white plastic retainer about 1/16" to release the cable.
    Use a spudger under one of the keys on the bottom row to very gently lift until you can use your hand to lift the keyboard.
    Mike Jackson-Polek - Réponse
    I tried to use those ifixit spudgers with several powerbooks to lift the white plastic retainers but it's too risky.. tiny, fragile, brittle plastics. I now use regular L-shaped tweezers, much safer, more control.
    Jamba - Réponse
  4. Apple Powerbook 5300 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 2 Apple Powerbook 5300 Hard Drive Replacement, Hard Drive: étape 4, image 2 de 2
    • Gently lift up the laptop's front-most panel and slowly raise the trackpad from the logic board.
    • Disconnect the front panel's ribbon cable from the board by slowly pulling it out of the connection port. Set the panel aside.
  5. Apple Powerbook 5300 Hard Drive Replacement: étape 5, image 1 de 2 Apple Powerbook 5300 Hard Drive Replacement: étape 5, image 2 de 2
    • Unscrew the Torx #8 screws holding the hard drive case in place on the logic board.
    • Lift up on the hard drive to disconnect its ribbon cable from the logic board, just like in the previous steps.
  6. Apple Powerbook 5300 Hard Drive Replacement: étape 6, image 1 de 2 Apple Powerbook 5300 Hard Drive Replacement: étape 6, image 2 de 2
    • Unscrew the four Torx #8 screws holding the hard drive to its case.
    • The hard drive can now be removed from its encasement.
2 autres ont terminé cette réparation.
Scott
Membre depuis le 04/26/11
155 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 25-30, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 25-30, Garner Spring 2011
CPSU-GARNER-S11S25G30
4 membres
6 tutoriels rédigés
1 commentaire de tutoriel
I was very surprised to find this guide and very pleased. Good work.
mayer - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 30
Total : 6,404
