Aller au contenu principal
Back Cover Removal
Back Cover Removal
Dominic DeLong
Dominic DeLong et 5 autres contributeurs
Dernière mise à jour le May 7, 2024
5 - 10 minutes
Facile
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
This will show you how to remove the back cover of the Dell Inspiron 11-3162. This is the starting point of all our guides here, and is necessary to reach the components of your laptop.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Back Cover Removal, Back Cover Removal: étape 1, image 1 de 2 Back Cover Removal, Back Cover Removal: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use tweezers to pry and remove the center screw cover on the back cover.
  2. Back Cover Removal: étape 2, image 1 de 2 Back Cover Removal: étape 2, image 2 de 2
    • Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
  3. Back Cover Removal: étape 3, image 1 de 1
    • Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
    • Do not fully remove the cover, as it is still attached to the laptop with cables.
  4. Back Cover Removal: étape 4, image 1 de 3 Back Cover Removal: étape 4, image 2 de 3 Back Cover Removal: étape 4, image 3 de 3
    • If you are only replacing the battery, you can skip this step. Be careful not to strain the still-connected cable as you work.
    • Unlock the wide ZIF connector securing the flex cable.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    • Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
Dominic DeLong
Membre depuis le 09/29/16
775 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 17
Total : 67
