Aller au contenu principal
Briggs and Stratton 675 Series Spark Plug Replacement
Andrew Saunders
Andrew Saunders et 4 autres contributeurs
Dernière mise à jour le July 23, 2021
5 - 10 minutes
Très facile
The spark plug is responsible for igniting the fuel in your engine. Over time, it will wear out and need to be replaced. This replacement is fairly simple and can be done anywhere in little time. You will need a 2" long 13/16" socket wrench to remove the spark plug.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: étape 1, image 1 de 2 Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: étape 1, image 2 de 2
    • Make sure the engine is turned off before beginning.
    • Use your hands to remove the spark plug wire. It should pop off easily with little effort
  2. Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: étape 2, image 1 de 3 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: étape 2, image 2 de 3 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: étape 2, image 3 de 3
    • Use a socket wrench with a 13/16" hex bit to unscrew the spark plug from the engine. You will probably need to use a long hex bit in order to get to the bolt.
    • Pull the spark plug out of its housing with your hands.
    • Alternatively, you may use a wrench or pliers to remove the spark plug instead. (Shown in the second image.)
7 autres ont terminé cette réparation.
Andrew Saunders
Membre depuis le 02/01/15
981 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 6-31, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
4 membres
18 tutoriels rédigés
13 commentaires de tutoriel
I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - Réponse
Any ideas I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - Réponse
pinch the front of black cap and pull off
tracy.mullen - Réponse
What size spark plug does this 675 series lawn mower take, I didn't see it listed?
Eris - Réponse
Kymberleah - Réponse
Who wrote this nonsense?
One important step in the replacement that was neglected was checking the proper Spark Plug Gap. Should you just take it out of the pack, without checking and install it? I wouldn’t.
Also, the Spark Plug should be installed with a Torque Wrench, setting it to 180 lb-in (20nm) . . . Heating and cooling of the Head, with an over-tightened Spark Plug could cause warping and if not tight enough, then loss of compression would result.
The correct Spark Plug depends upon Briggs & Stratton Engine Model and Date of Manufacture.
https://www.briggsandstratton.com/eu/en_...
https://www.briggsandstratton.com/na/en_...
shepherds_pie - Réponse
My 675 series more floods real easily when it is cold or if after using it for a while I take a break. If the break is about 30 minutes it simply will flood and not stat again. Any suggestions?
George Wright - Réponse
What is the spark plug gap on the Briggs 190 cc 6.75 engine
Phillip - Réponse
Briggs & Stratton Replacement Spark Plug RJ19LMC you may want to include the type of spark plug gap is .030
tom_simmonds - Réponse
My Briggs and Stratton started on 2 pull everytime and now just out of the blue it starts then it dies, any idea
Rgebhart79@gmail.com - Réponse
Can't start 6.75 briggs & Stratton Brute 22 inch mover replaced sparkplug airfilter drained gas tank , new gas , fuel filter hoses fine , pulled carburetor cleaned out dissassembled , auto choke-butterfly is in closed position when cold , i havent replaced the whole carburetor kit yet, the gaskets o ring are original , carburetor bowl bolt nut & sparkplug is wet with gas there are no leaks, cant verify to .030 sparkplug gap exists on the plug, i am bewildered, please help anyone
Kevin Marek - Réponse
Same issue with mine. Have you found the problem?
Revolución Pictures -
Same issue, wont start, new fuel, filters, spark plug, R&R & cleaned carberator, all housing, springs linkages and hoses, gaskets like new. Gets fuel, air and spark all good. Any suggestions?
carson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 16
7 derniers jours : 106
30 derniers jours : 321
Total : 49,863
