Aller au contenu principal
CHUWI GemiBook XPro Battery Replacement
JakeV
JakeV et 4 autres contributeurs
Dernière mise à jour le December 18, 2024
10 - 15 minutes
Modérée
Tutoriel étudiant vedette
You may find it necessary to replace the battery on the CHUWI GemiBook XPro due to its charging rate or capacity. This easy-to-follow guide will assist in the process of battery removal and replacement. For this guide you’ll need a philips #1 screwdriver, the spudger, and opening picks in order to disassemble and replace the battery in an orderly fashion.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. CHUWI GemiBook XPro Battery Replacement, Lower Case: étape 1, image 1 de 2 CHUWI GemiBook XPro Battery Replacement, Lower Case: étape 1, image 2 de 2
    • Discharge the battery below 25%, since a charged lithium-ion battery is a potential safety hazard. Fully power down the laptop and unplug any peripheries.
    • Orient the device to where you can see the bottom of the case.
    • Use a Phillips #1 screwdriver to remove the twelve 5.6 mm screws that secure the lower case.
  2. CHUWI GemiBook XPro Battery Replacement: étape 2, image 1 de 3 CHUWI GemiBook XPro Battery Replacement: étape 2, image 2 de 3 CHUWI GemiBook XPro Battery Replacement: étape 2, image 3 de 3
    • Insert an opening pick into the gap between the lower case and the chassis.
    • Pry along the entire perimeter of the laptop until the lower case fully releases.
    • Lift the lower case up and off of the chassis.
  3. CHUWI GemiBook XPro Battery Replacement, Battery: étape 3, image 1 de 2 CHUWI GemiBook XPro Battery Replacement, Battery: étape 3, image 2 de 2
    • Peel off the black tape on the upper-right side of the motherboard.
  4. CHUWI GemiBook XPro Battery Replacement: étape 4, image 1 de 2 CHUWI GemiBook XPro Battery Replacement: étape 4, image 2 de 2
    • Use two opening tools or your fingernails to carefully "walk" the battery connector out of its socket.
  5. CHUWI GemiBook XPro Battery Replacement: étape 5, image 1 de 3 CHUWI GemiBook XPro Battery Replacement: étape 5, image 2 de 3 CHUWI GemiBook XPro Battery Replacement: étape 5, image 3 de 3
    • Unseat the speaker wires and antenna wire from their retaining hooks on the battery with a halberd spudger.
  6. CHUWI GemiBook XPro Battery Replacement: étape 6, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the five 4.3 mm screws that secure the battery.
  7. CHUWI GemiBook XPro Battery Replacement: étape 7, image 1 de 3 CHUWI GemiBook XPro Battery Replacement: étape 7, image 2 de 3 CHUWI GemiBook XPro Battery Replacement: étape 7, image 3 de 3
    • Lift the battery up and out of the chassis.
For optimal performance, after completing this guide, calibrate your newly installed battery.
JakeV
Membre depuis le 08/28/24
407 Réputation
3 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 66
Total : 298
