Aller au contenu principal
CHUWI GemiBook XPro SSD Replacement
JakeV
JakeV et 3 autres contributeurs
Dernière mise à jour le December 18, 2024
15 - 25 minutes
Modérée
Despite the already large 256GB capacity of the CHUWI Gemibook XPro, you may desire a larger storage space if you handle many files or downloads. This simple guide will assist you in removing and replacing the SSD. For this guide, you will only need a Phillips #0 screwdriver (PH0 bit) and a replacement M.2 2280 SSD.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. CHUWI GemiBook XPro SSD Replacement, Battery: étape 1, image 1 de 2 CHUWI GemiBook XPro SSD Replacement, Battery: étape 1, image 2 de 2
    • Peel off the black tape on the upper-right side of the motherboard.
  2. CHUWI GemiBook XPro SSD Replacement: étape 2, image 1 de 2 CHUWI GemiBook XPro SSD Replacement: étape 2, image 2 de 2
    • Use two opening tools or your fingernails to carefully "walk" the battery connector out of its socket.
  3. CHUWI GemiBook XPro SSD Replacement: étape 3, image 1 de 3 CHUWI GemiBook XPro SSD Replacement: étape 3, image 2 de 3 CHUWI GemiBook XPro SSD Replacement: étape 3, image 3 de 3
    • Unseat the speaker wires and antenna wire from their retaining hooks on the battery with a halberd spudger.
  4. CHUWI GemiBook XPro SSD Replacement: étape 4, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the five 4.3 mm screws that secure the battery.
  5. CHUWI GemiBook XPro SSD Replacement: étape 5, image 1 de 3 CHUWI GemiBook XPro SSD Replacement: étape 5, image 2 de 3 CHUWI GemiBook XPro SSD Replacement: étape 5, image 3 de 3
    • Lift the battery up and out of the chassis.
  6. CHUWI GemiBook XPro SSD Replacement, SSD: étape 6, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the single 3 mm screw securing the SSD.
  7. CHUWI GemiBook XPro SSD Replacement: étape 7, image 1 de 3 CHUWI GemiBook XPro SSD Replacement: étape 7, image 2 de 3 CHUWI GemiBook XPro SSD Replacement: étape 7, image 3 de 3
    • Carefully grip and pull the SSD out of its port.
    • Make sure to purchase the correct form factor of the SSD. The CHUWI GemiBook XPro uses 2280 size M.2 SSD.
JakeV
Membre depuis le 08/28/24
407 Réputation
3 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 8
30 derniers jours : 63
Total : 194
