Aller au contenu principal
Canon PowerShot SD400 LCD Replacement
Yi Huang Ke
Yi Huang Ke et 12 autres contributeurs
Dernière mise à jour le October 14, 2024
Aucune estimation
Modérée
Étapes à raccourcir
Outils incorrects
Problème de balise
Étapes manquantes
Détails manquants
This guide offers detailed, step-by-step instructions for replacing a faulty LCD screen on your Canon PowerShot SD400. The LCD, or liquid crystal display, serves as the camera's monitor for images, and it may require replacement if you notice cracks, discolored pixels, spots, blobs, flickering, or a complete loss of image signal. Before you get started, make sure to power off the camera and remove the battery.
Ce dont vous avez besoin
Outils
  1. Canon PowerShot SD400 LCD Replacement, Battery: étape 1, image 1 de 2 Canon PowerShot SD400 LCD Replacement, Battery: étape 1, image 2 de 2
    • Slide the battery cover open (indicated by the blue box).
  2. Canon PowerShot SD400 LCD Replacement: étape 2, image 1 de 1
    • Push in the orange clip (indicated by the blue box) to eject the battery.
  3. Canon PowerShot SD400 LCD Replacement: étape 3, image 1 de 1
    • Insert the charged battery back into the slot (indicated by the blue box).
    • Close the cover.
  4. Canon PowerShot SD400 LCD Replacement, LCD: étape 4, image 1 de 3 Canon PowerShot SD400 LCD Replacement, LCD: étape 4, image 2 de 3 Canon PowerShot SD400 LCD Replacement, LCD: étape 4, image 3 de 3
    • Locate these six screws that need to be removed to open the camera’s housing. These screws can be found on the bottom and both sides of the camera.
  5. Canon PowerShot SD400 LCD Replacement: étape 5, image 1 de 3 Canon PowerShot SD400 LCD Replacement: étape 5, image 2 de 3 Canon PowerShot SD400 LCD Replacement: étape 5, image 3 de 3
    • Using the screwdriver, carefully remove the exterior screws and place them in a safe location to avoid misplacing them.
  6. Canon PowerShot SD400 LCD Replacement: étape 6, image 1 de 2 Canon PowerShot SD400 LCD Replacement: étape 6, image 2 de 2
    • Locate the interior screw that is above the top right of the LCD screen.
    • Remove the screw using the screwdriver.
  7. Canon PowerShot SD400 LCD Replacement: étape 7, image 1 de 3 Canon PowerShot SD400 LCD Replacement: étape 7, image 2 de 3 Canon PowerShot SD400 LCD Replacement: étape 7, image 3 de 3
    • Locate the two clips on the left side of the LCD screen.
    • Carefully insert the tip of a flat-head screwdriver under the two clips of the LCD screen.
    • Slowly lift the screen using the flat-head screwdriver.
    • Potential for device damage Lift the screen gently to avoid any damage.
    Then what what to do next
    Keeneh Weah Cisco - Réponse
2 autres ont terminé cette réparation.
Yi Huang Ke
Membre depuis le 10/18/11
51 Réputation
4 tutoriels rédigés
Équipe
James Madison, Team 1-1, Allen Fall 2011 Membre de l'équipe James Madison, Team 1-1, Allen Fall 2011
JMU-ALLEN-F11S1G1
4 membres
4 tutoriels rédigés
1 commentaire de tutoriel
Do you carry a lcd screen for the Powershot sd400?
Jesus Licon - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 44
Total : 3,336
