Aller au contenu principal
Cuisinart Mini-Prep DLC-2A Button Replacement
Xavier Tapia
Xavier Tapia et un autre contributeur
Dernière mise à jour le January 5, 2018
5 - 10 minutes
Facile
Use this guide to replace the "Chop" and "Grind" buttons located on the Cuisinart Mini-Prep DLC-2A.
Ce dont vous avez besoin
Outils
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. Cuisinart Mini-Prep DLC-2A Button Replacement, Cuisinart Mini-Prep DLC-2A Case Disassembly: étape 1, image 1 de 2 Cuisinart Mini-Prep DLC-2A Button Replacement, Cuisinart Mini-Prep DLC-2A Case Disassembly: étape 1, image 2 de 2
    • Remove the back panel using a Phillips #1 Screwdriver on the four screws that hold it in place.
    My DLC-2ARA has 3 std Phillips screws & 1 unidentifiable right rear, maybe security screw. Anyone know which driver head to use please?
    Phillip Robinson - Réponse
  2. Cuisinart Mini-Prep DLC-2A Button Replacement, Button: étape 2, image 1 de 1
    • Locate the Button Panel inside the blender.
    • Using your Phillips #1 Screwdriver, remove the two screws which hold the panel in place.
  3. Cuisinart Mini-Prep DLC-2A Button Replacement: étape 3, image 1 de 3 Cuisinart Mini-Prep DLC-2A Button Replacement: étape 3, image 2 de 3 Cuisinart Mini-Prep DLC-2A Button Replacement: étape 3, image 3 de 3
    • Locate the black box held in place on the panel.
    • Using your Spudger, wedge the black box out of its place to uncover the button
  4. Cuisinart Mini-Prep DLC-2A Button Replacement: étape 4, image 1 de 2 Cuisinart Mini-Prep DLC-2A Button Replacement: étape 4, image 2 de 2
    • Once the black box is out of place, use your finger to push out the button.
    • Now replace the old button with your newly acquired button.
Xavier Tapia
Membre depuis le 09/25/17
144 Réputation
1 tutoriel rédigé
Équipe
1 commentaire de tutoriel
Hi,
Where’d you get the new buttons?
Mark B - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 335
