Aller au contenu principal
Dell Inspiron 13-7373 Back Cover Replacement
Kristen Gismondi
Kristen Gismondi et 4 autres contributeurs
Dernière mise à jour le June 27, 2023
4 minutes
Facile
This back cover replacement repair is for the Dell Inspiron 13-7373 laptop. A repair like this is typically needed when there is damage to the back cover exposing components or when some components need to be replaced. If your back cover is causing reduced airflow or has sharp edges because it’s cracked or broken, you probably need to replace it. There is nothing unusual about this repair and requires no special skills to be performed.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 13-7373 Back Cover Replacement, Back Cover: étape 1, image 1 de 3 Dell Inspiron 13-7373 Back Cover Replacement, Back Cover: étape 1, image 2 de 3 Dell Inspiron 13-7373 Back Cover Replacement, Back Cover: étape 1, image 3 de 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
Kristen Gismondi
Membre depuis le 11/12/14
92 096 Réputation
241 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 455 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 22
Total : 802
