Aller au contenu principal
Dell Inspiron 13-7373 Network Card Replacement
Kristen Gismondi
Kristen Gismondi et 3 autres contributeurs
Dernière mise à jour le July 6, 2023
15 minutes
Modérée
Use this guide to replace a malfunctioning or non-functioning network card in your Dell Inspiron 13-7373 laptop.
The network card allows data to be transmitted between the computer and a connected network. A faulty network card will limit your computer’s ability to communicate with wired and wireless networks.
Replacing the network card may resolve your laptop’s inability to display or connect to available networks. If you can connect, but regularly experience intermittent or slow connection, replacing the card may improve the device’s performance in these areas.  Performing an internet speed test will assist you in determining if your connection to available networks is inadequate.
Before you begin, be sure to turn off your laptop and disconnect it from any external power source.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Inspiron 13-7373 Network Card Replacement, Back Cover: étape 1, image 1 de 3 Dell Inspiron 13-7373 Network Card Replacement, Back Cover: étape 1, image 2 de 3 Dell Inspiron 13-7373 Network Card Replacement, Back Cover: étape 1, image 3 de 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Network Card Replacement, Network Card: étape 2, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
Kristen Gismondi
Membre depuis le 11/12/14
92 126 Réputation
241 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 465 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 28
Total : 621
