Aller au contenu principal
Dell Inspiron 1318 Memory Module Replacement
Terrence15
Terrence15 et 2 autres contributeurs
Dernière mise à jour le November 14, 2019
50 secondes - 4 minutes
Très facile
Conditions préalables manquantes
Tutoriel réalisé par la communauté
In this guide, we will show you how to remove and replace the Memory Module.
  1. Dell Inspiron 1318 Memory Module Replacement, Popping up the Memory Module: étape 1, image 1 de 1
    • Follow the procedures in Before You Begin.
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  2. Dell Inspiron 1318 Memory Module Replacement, Remove the Module: étape 2, image 1 de 1
    • Remove the module from the connector.
  3. Dell Inspiron 1318 Memory Module Replacement, Align the Notch: étape 3, image 1 de 1
    • Align the notch in the module edge connector with the tab in the connector slot.
  4. Dell Inspiron 1318 Memory Module Replacement, Sliding the Module: étape 4, image 1 de 1
    • Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If the module does not click into place, remove the module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 585 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 105
