Aller au contenu principal
Dell Inspiron 14 5100 Touch Pad Replacement
Jonn Ross Olofernes
Jonn Ross Olofernes et 2 autres contributeurs
Dernière mise à jour le December 11, 2019
20 minutes
Modérée
Verify with the device’s troubleshooting page whether the replacement of your touchpad is required for your situation.
This guide will go through the process of replacing the touchpad for the Dell Inspiron 14 5100.
A faulty touchpad can cause the inability to use the cursor when the device is in use.
If this guide is unnecessary, go to our device page to look for the correct guide for your situation.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 14 5100 Touch Pad Replacement, Dell Inspiron 14 5100 Disassembly: étape 1, image 1 de 3 Dell Inspiron 14 5100 Touch Pad Replacement, Dell Inspiron 14 5100 Disassembly: étape 1, image 2 de 3 Dell Inspiron 14 5100 Touch Pad Replacement, Dell Inspiron 14 5100 Disassembly: étape 1, image 3 de 3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Touch Pad Replacement: étape 2, image 1 de 2 Dell Inspiron 14 5100 Touch Pad Replacement: étape 2, image 2 de 2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Touch Pad Replacement, Battery: étape 3, image 1 de 2 Dell Inspiron 14 5100 Touch Pad Replacement, Battery: étape 3, image 2 de 2
    • Remove the four Phillips #0 screws securing the battery to the keyboard assembly.
  4. Dell Inspiron 14 5100 Touch Pad Replacement: étape 4, image 1 de 3 Dell Inspiron 14 5100 Touch Pad Replacement: étape 4, image 2 de 3 Dell Inspiron 14 5100 Touch Pad Replacement: étape 4, image 3 de 3
    • Peel off the tape securing the battery cable to the battery cable connector.
    • Disconnect and remove the old battery.
  5. Dell Inspiron 14 5100 Touch Pad Replacement, Touch Pad: étape 5, image 1 de 3 Dell Inspiron 14 5100 Touch Pad Replacement, Touch Pad: étape 5, image 2 de 3 Dell Inspiron 14 5100 Touch Pad Replacement, Touch Pad: étape 5, image 3 de 3
    • Disconnect the touchpad cable attached to the motherboard.
    • Be careful lifting the Flat Flex Cable (FFC) connector as it is quite fragile.
  6. Dell Inspiron 14 5100 Touch Pad Replacement: étape 6, image 1 de 2 Dell Inspiron 14 5100 Touch Pad Replacement: étape 6, image 2 de 2
    • Peel off the tapes securing the touchpad to the keyboard assembly.
  7. Dell Inspiron 14 5100 Touch Pad Replacement: étape 7, image 1 de 1
    • Remove the four screws securing the touchpad to the keyboard assembly using the Phillips #0 screwdriver.
  8. Dell Inspiron 14 5100 Touch Pad Replacement: étape 8, image 1 de 3 Dell Inspiron 14 5100 Touch Pad Replacement: étape 8, image 2 de 3 Dell Inspiron 14 5100 Touch Pad Replacement: étape 8, image 3 de 3
    • Remove the three screws securing the touchpad bracket to the keyboard assembly using the Phillips #0 screwdriver.
    • Lift the touchpad bracket.
  9. Dell Inspiron 14 5100 Touch Pad Replacement: étape 9, image 1 de 2 Dell Inspiron 14 5100 Touch Pad Replacement: étape 9, image 2 de 2
    • Lif tthe touchpad and replace with the new touchpad.
    • Make sure to guide the touchpad cable along with the touchpad to avoid damaging the parts.
    • Lift the touchpad at an angle from under the touchpad bracket to avoid damaging the touchpad or the touchpad bracket.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 25
Total : 1,141
