Dell Inspiron 15-7559 Battery Replacement
Introduction
Passez à l'étape 1This guide will demonstrate how to replace the battery for the Dell Inspiron 15-7559. This may be necessary if you have issues charging or turning on the device.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Ce dont vous avez besoin
Turn off the computer.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Use the blue, plastic opening tool to gently pry a section of the back panel open.
Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
After the clips have been disconnected, the back panel can then be easily lifted off the computer.
11 autres ont terminé cette réparation.
2 commentaires
Cool, that’s the easy part. How do you tell the UEFI that it’s okay to charge the new battery?
is it ok to replace the 11.4V battery with the 11.1V version?
