Dell Inspiron 1501 Wireless Mini-Card Replacement
Introduction
Passez à l'étape 1This guide will teach you how to replace the wireless mini-card in your laptop.
Ce dont vous avez besoin
Place the laptop facedown with the battery facing you.
Push the switch above the battery to the right and hold it in that position.
Lift the battery using the grip on the top and remove it from its socket.
Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
Insert the spudger underneath the groove on the right side of the hinge cover.
Push up to pry the edge of the hinge cover out.
Lift up to release the hinge cover from the laptop, working from right to left.
Remove the two 5mm JIS #1 screws from the top of the keyboard.
Lift the top of the keyboard up and pull the keyboard away from the laptop.
Remove the two wires from their connections.
Pull the metal tabs securing the wireless mini-card to the back of the laptop until the card pops up.
Remove the wireless mini-card from the laptop.
1 commentaire de tutoriel
I have a computer like this. I have a problem that I have not been able to find a solution too. A few parts that support the screen are broken, and I need to know if I will not be able to replace the CPU in the future should I ever decide to cement these specific parts together.
Let me know if you need any more information!
Peter C.
