Aller au contenu principal
Dell Inspiron 3520 Keyboard Replacement
Ian
Ian et 3 autres contributeurs
Dernière mise à jour le August 9, 2019
5 minutes
Facile
The Dell Inspiron 3520 has a basic keyboard that is easily accessible from the open surface of the notebook. The 3520 model does not have a keyboard backlight. This makes the keyboard much simpler to remove. Keep in mind that this will require some force on the repairers part.
Ce dont vous avez besoin
Outils
  • Spudger
    Spudger
  1. Dell Inspiron 3520 Keyboard Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 3520 Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 Keyboard Replacement: étape 2, image 1 de 3 Dell Inspiron 3520 Keyboard Replacement: étape 2, image 2 de 3 Dell Inspiron 3520 Keyboard Replacement: étape 2, image 3 de 3
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 Keyboard Replacement, Keyboard: étape 3, image 1 de 2 Dell Inspiron 3520 Keyboard Replacement, Keyboard: étape 3, image 2 de 2
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 Keyboard Replacement: étape 4, image 1 de 1
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 Keyboard Replacement: étape 5, image 1 de 2 Dell Inspiron 3520 Keyboard Replacement: étape 5, image 2 de 2
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
7 autres ont terminé cette réparation.
Ian
Membre depuis le 01/30/15
1 557 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 16-2, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 membres
5 tutoriels rédigés
1 commentaire de tutoriel
Hi, any ideas why a NEW keyboard still wouldn't work after installing it? The ribbon was connected properly, it’s the right keyboard, and I made sure the driver was updated. Any help would be greatly appreciated. Started a new job and my keyboard went to $@$* in the first week. Can’t really afford to buy a new laptop this weekend. It works with an external USB keyboard so it’s probably not a software issue… I think?
Alittle advice would be greatly appreciated. Thanks!
Stumpedu - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 7
30 derniers jours : 24
Total : 6,429
