Aller au contenu principal
Dell Inspiron 6000 Keyboard Replacement
Jacob DeWar
Jacob DeWar et 4 autres contributeurs
Dernière mise à jour le January 8, 2015
10 - 15 minutes
Facile
Removing and replacing the keyboard requires some disassembly and time.
Ce dont vous avez besoin
Outils
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. Dell Inspiron 6000 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 Keyboard Replacement: étape 2, image 1 de 1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 Keyboard Replacement, Keyboard: étape 3, image 1 de 3 Dell Inspiron 6000 Keyboard Replacement, Keyboard: étape 3, image 2 de 3 Dell Inspiron 6000 Keyboard Replacement, Keyboard: étape 3, image 3 de 3
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
  4. Dell Inspiron 6000 Keyboard Replacement: étape 4, image 1 de 2 Dell Inspiron 6000 Keyboard Replacement: étape 4, image 2 de 2
    • Remove two 4 mm Philips #00 screws.
  5. Dell Inspiron 6000 Keyboard Replacement: étape 5, image 1 de 1
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
  6. Dell Inspiron 6000 Keyboard Replacement: étape 6, image 1 de 3 Dell Inspiron 6000 Keyboard Replacement: étape 6, image 2 de 3 Dell Inspiron 6000 Keyboard Replacement: étape 6, image 3 de 3
    • Gently pull the blue tab up until it comes away from computer.
    What kind of connector does the keyboard use I want to try and fit a newer motherboard in my old laptop
    Aaron Stanley - Réponse
5 autres ont terminé cette réparation.
Jacob DeWar
Membre depuis le 09/23/14
533 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 11-1, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 membres
7 tutoriels rédigés
1 commentaire de tutoriel
Hi there, my dell inspiron 6000 does not power up when I switch on. This happened after I remove my keypad to clean.. Any idea why?
John KAPA - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 2,222
