Aller au contenu principal
Dell Inspiron 7568 Hard-Drive Replacement
Elijah Basile
Elijah Basile et 3 autres contributeurs
Dernière mise à jour le December 20, 2019
5 minutes
Modérée
When removing or replacing the hard drive of the Dell Inspiron 7568 it is important to make sure the laptop it is unplugged and completely turned off. User should also remember to be careful when unplugging and removing the battery. It is recommended that users keep different screw types separated to keep assembly easier. Make sure to uses a Phillips head #1 screw driver.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 7568 Hard-Drive Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 7568 Hard-Drive Replacement, Battery: étape 1, image 2 de 2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Hard-Drive Replacement: étape 2, image 1 de 2 Dell Inspiron 7568 Hard-Drive Replacement: étape 2, image 2 de 2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Hard-Drive Replacement, Hard-Drive: étape 3, image 1 de 1
    • Remove the three 3mm Phillips #1 screws connecting the hard drive to the laptop.
  4. Dell Inspiron 7568 Hard-Drive Replacement: étape 4, image 1 de 2 Dell Inspiron 7568 Hard-Drive Replacement: étape 4, image 2 de 2
    • Disconnect the highlighted SATA cable from the hard drive.
  5. Dell Inspiron 7568 Hard-Drive Replacement: étape 5, image 1 de 1
    • Remove the four 3mm Phillips #1 screws of the hard drive. Both sides look identical.
  6. Dell Inspiron 7568 Hard-Drive Replacement: étape 6, image 1 de 1
    • Remove the hard drive (right) from its frame (left).
Elijah Basile
Membre depuis le 11/06/19
358 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S1-G4, Stella Fall 2019 Membre de l'équipe IUPUI, Team S1-G4, Stella Fall 2019
IUPUI-STELLA-F19S1G4
4 membres
4 tutoriels rédigés
1 commentaire de tutoriel
Will a 9mm 2.5” SSD fit in these? or can it be forced in? p16 of the spec sheet says “7mm” but I’m not sure if that’s just saying stock configuration just comes with a 7mm drive? or that it only supports up to 7mm?: https://dl.dell.com/manuals/all-products... Any clarification appreciated, thanks!
Blacknova - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 399
