Aller au contenu principal
Dell Inspiron N5050 RAM Replacement
Kristy Mayo
Kristy Mayo et un autre contributeur
Dernière mise à jour le December 20, 2016
5 - 10 minutes
Facile
Remember to follow the battery removal steps before proceeding with replacing the RAM. In this guide, you will lift the keyboard cable and remove the RAM component out of your device. Remove these components carefully to prevent damage. You will need a plastic opening tool and a screwdriver for these steps.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Inspiron N5050 RAM Replacement, Battery: étape 1, image 1 de 1
    • Flip your laptop over to view the bottom and the two locks.
    How many gb hard drive can I install on Inspiron n5050
    Anguiano pro - Réponse
  2. Dell Inspiron N5050 RAM Replacement: étape 2, image 1 de 1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron N5050 RAM Replacement: étape 3, image 1 de 2 Dell Inspiron N5050 RAM Replacement: étape 3, image 2 de 2
    • Pull the battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron N5050 RAM Replacement, RAM: étape 4, image 1 de 1
    • Remove the eleven 5mm palmrest screws from the bottom of the laptop with a Phillips #PH00 screw.
    • Remove the two 3mm hard drive screws from the bottom of the laptop with a Phillips #PH00 screw.
  5. Dell Inspiron N5050 RAM Replacement: étape 5, image 1 de 2 Dell Inspiron N5050 RAM Replacement: étape 5, image 2 de 2
    • Flip over and open the laptop to view the keyboard.
    • Use a plastic opening tool to press down on four clips, one by one.
    • Press down on the clips and pull the tool towards you to pry the keyboard loose.
    • The four clips are above the Esc, F6, F11, and Delete keys.
  6. Dell Inspiron N5050 RAM Replacement: étape 6, image 1 de 3 Dell Inspiron N5050 RAM Replacement: étape 6, image 2 de 3 Dell Inspiron N5050 RAM Replacement: étape 6, image 3 de 3
    • Remove the keyboard carefully.
    • Make sure to lift the keyboard gently, because a cable is connected to the back.
    • Flip the keyboard over to find the keyboard cable.
    • Pull the cable labeled "UP" out to disconnect it from the laptop.
  7. Dell Inspiron N5050 RAM Replacement: étape 7, image 1 de 3 Dell Inspiron N5050 RAM Replacement: étape 7, image 2 de 3 Dell Inspiron N5050 RAM Replacement: étape 7, image 3 de 3
    • Find the RAM and pull apart the two clips.
    • After pulling apart both clips, the RAM component will snap up.
  8. Dell Inspiron N5050 RAM Replacement: étape 8, image 1 de 2 Dell Inspiron N5050 RAM Replacement: étape 8, image 2 de 2
    • Remove the RAM.
8 autres ont terminé cette réparation.
Kristy Mayo
Membre depuis le 09/15/16
1 508 Réputation
3 tutoriels rédigés
Équipe
1 commentaire de tutoriel
Thanks Kristy,
I was breath new life back into an old laptop and re-purpose after upgrading the RAM.
jason acn - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 17
Total : 2,524
