Dell Inspiron n5110 Display Assembly Replacement
Introduction
Passez à l'étape 1In this guide, we will be showing you how to remove and replace the Display Assembly.
Ce dont vous avez besoin
Outils
Remove the two screws that secure the display assembly to the computer base.
Disconnect the display cable and touch-screen cable from the system-board connectors.
Note the routing of the Mini-Card antenna cables and remove the cables from the routing guides.
Remove the four screws that secure the display assembly to the computer base.
Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
Connect the display cable and touch-screen cable to the connectors on the system board.
Replace the two screws that secure the display assembly to the computer base.
3 autres ont terminé cette réparation.
1 commentaire de tutoriel
can someone help me , i have the Dell Inspiron N5110 , the display was broken but has worked for long time and one time has not work anymore and the laptop peeps 8 times every 3-5 sec, and i removed the screen and tried to connecte it to external screen but also nothing happen and still peeping 8 times , anyone can help?
