Aller au contenu principal
Epson PowerLite 83+ Projector Lens Replacement
Billy Fox
Billy Fox et 2 autres contributeurs
Dernière mise à jour le May 26, 2022
20 - 50 minutes
Modérée
If the image is blurred, out of focus or distorted, and the cause is not in the menu settings or lens smudges, the projector lens may need to be replaced. Prior to replacement, refer to the Troubleshooting page for additional solutions. Follow this guide to replace the projector lens of your Epson PowerLite 83+ projector.
Before beginning this repair, make sure the the projector is off and unplugged from the power adapter.
Ce dont vous avez besoin
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Epson PowerLite 83+ Projector Lens Replacement, Motherboard: étape 1, image 1 de 3 Epson PowerLite 83+ Projector Lens Replacement, Motherboard: étape 1, image 2 de 3 Epson PowerLite 83+ Projector Lens Replacement, Motherboard: étape 1, image 3 de 3
    • Remove the eight 5mm Phillips #2 screws securing the projector's bottom cover.
    • A long shank Phillips #2 screwdriver is required to reach the screws.
  2. Epson PowerLite 83+ Projector Lens Replacement: étape 2, image 1 de 3 Epson PowerLite 83+ Projector Lens Replacement: étape 2, image 2 de 3 Epson PowerLite 83+ Projector Lens Replacement: étape 2, image 3 de 3
    • Flip the projector over and lift the top cover from the rear of the projector.
    • Two cables are connected at the front that prevent full removal.
    • Disconnect the slide cover JST connector. Grip the connector and rock it back and forth while apply gentle pressure.
  3. Epson PowerLite 83+ Projector Lens Replacement: étape 3, image 1 de 2 Epson PowerLite 83+ Projector Lens Replacement: étape 3, image 2 de 2
    • Using a spudger, lift the ribbon cable's locking tab along the length of the cable.
    • Remove the ribbon cable from the connector and place the projector's top cover aside.
  4. Epson PowerLite 83+ Projector Lens Replacement: étape 4, image 1 de 3 Epson PowerLite 83+ Projector Lens Replacement: étape 4, image 2 de 3 Epson PowerLite 83+ Projector Lens Replacement: étape 4, image 3 de 3
    • Remove the two 6 mm Phillips #2 screws.
    • Remove the single silver 5 mm Phillips #2 screw.
  5. Epson PowerLite 83+ Projector Lens Replacement: étape 5, image 1 de 3 Epson PowerLite 83+ Projector Lens Replacement: étape 5, image 2 de 3 Epson PowerLite 83+ Projector Lens Replacement: étape 5, image 3 de 3
    • Using your fingernails or a spudger, remove the eleven JST connectors attached to the motherboard.
  6. Epson PowerLite 83+ Projector Lens Replacement: étape 6, image 1 de 2 Epson PowerLite 83+ Projector Lens Replacement: étape 6, image 2 de 2
    • Using a spudger, flip up the plastic locking tabs and gently remove the three ribbon cables from their connectors.
  7. Epson PowerLite 83+ Projector Lens Replacement: étape 7, image 1 de 2 Epson PowerLite 83+ Projector Lens Replacement: étape 7, image 2 de 2
    • Ensure all JST connectors are clear of the motherboard and that the ribbon cables freely move in their motherboard cutouts.
    • Lift the motherboard from the front side of the projector to clear the ribbon cables.
    • Disconnect the speaker's JST connector on the underside of the motherboard using your fingernails.
    • Remove the motherboard from the case.
  8. Epson PowerLite 83+ Projector Lens Replacement, Projector Lens: étape 8, image 1 de 3 Epson PowerLite 83+ Projector Lens Replacement, Projector Lens: étape 8, image 2 de 3 Epson PowerLite 83+ Projector Lens Replacement, Projector Lens: étape 8, image 3 de 3
    • Remove the four 6 mm Phillips #2 screws securing the fan bracket.
    • Remove the fan bracket by pulling straight up and set it aside.
  9. Epson PowerLite 83+ Projector Lens Replacement: étape 9, image 1 de 3 Epson PowerLite 83+ Projector Lens Replacement: étape 9, image 2 de 3 Epson PowerLite 83+ Projector Lens Replacement: étape 9, image 3 de 3
    • Remove the four 6 mm Phillips #2 screws securing the projector lens.
  10. Epson PowerLite 83+ Projector Lens Replacement: étape 10, image 1 de 2 Epson PowerLite 83+ Projector Lens Replacement: étape 10, image 2 de 2
    • Unhook the JST connector wire from wire stay and move it aside.
    • Remove the projector lens from the base.
Billy Fox
Membre depuis le 02/22/22
467 Réputation
3 tutoriels rédigés
Équipe
Clemson, Team 2-4, Hunter Spring 2022 Membre de l'équipe Clemson, Team 2-4, Hunter Spring 2022
CLEM-HUNTER-S22S2G4
4 membres
6 tutoriels rédigés
1 commentaire de tutoriel
source for a replacement lens? I surely need one.
christopher wanko - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 17
Total : 563
