Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixel 2 Fingerprint Sensor Replacement
Ce dont vous avez besoin
  1. Google Pixel 2 Fingerprint Sensor Replacement, Opening Procedure: étape 1, image 1 de 2 Google Pixel 2 Fingerprint Sensor Replacement, Opening Procedure: étape 1, image 2 de 2
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. This also makes a smooth surface allowing the suction cup to bond.
    • Apply a suction cup as close to the volume button edge of the phone as you can while avoiding the curved edge.
    • The suction cup will not make a good seal on the curved portion of the glass.
    Demander à FixBot
    Ajouter un commentaire
  2. Google Pixel 2 Fingerprint Sensor Replacement: étape 2, image 1 de 3 Google Pixel 2 Fingerprint Sensor Replacement: étape 2, image 2 de 3 Google Pixel 2 Fingerprint Sensor Replacement: étape 2, image 3 de 3
    • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
    • Do not insert the pick deeper than 1.5 mm, or you risk damaging the OLED panel.
    • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
    • The display panel is fragile. If you plan to re-use your display, take care to insert your tool only as far as necessary to separate the adhesive. Inserting the tool any further can damage the OLED panel under the glass.
    Demander à FixBot
  3. Google Pixel 2 Fingerprint Sensor Replacement: étape 3, image 1 de 2 Google Pixel 2 Fingerprint Sensor Replacement: étape 3, image 2 de 2
    • In the following steps, extra caution is required in certain areas to avoid damage to the phone:
    • Do not insert the pick more than 9 mm into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel it can damage the display.
    • Only make very shallow cuts in the upper left corner, prying deeply can damage the front-facing camera.
    • Inserting an opening tool deeper than 1.5 mm into the sides of the device, or 9 mm into the top and bottom can permanently damage the display.
    Demander à FixBot
  4. Google Pixel 2 Fingerprint Sensor Replacement: étape 4, image 1 de 2 Google Pixel 2 Fingerprint Sensor Replacement: étape 4, image 2 de 2
    • In the following steps, use the flat of the opening pick, rather than a corner, to cut here. This will help prevent inserting the pick too deeply.
    • Slide the opening pick up the right side of the phone to separate the display adhesive.
    • Take extra care with the side bezels, which are only 1.5 mm deep.
    Demander à FixBot
  5. Google Pixel 2 Fingerprint Sensor Replacement: étape 5, image 1 de 3 Google Pixel 2 Fingerprint Sensor Replacement: étape 5, image 2 de 3 Google Pixel 2 Fingerprint Sensor Replacement: étape 5, image 3 de 3
    • Slide the opening pick around the upper-right corner and along the top edge of the phone.
    • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
    Demander à FixBot
  6. Google Pixel 2 Fingerprint Sensor Replacement: étape 6, image 1 de 3 Google Pixel 2 Fingerprint Sensor Replacement: étape 6, image 2 de 3 Google Pixel 2 Fingerprint Sensor Replacement: étape 6, image 3 de 3
    • Slide the pick around the upper-left corner of the phone and down the left edge of the phone.
    Demander à FixBot
  7. Google Pixel 2 Fingerprint Sensor Replacement: étape 7, image 1 de 3 Google Pixel 2 Fingerprint Sensor Replacement: étape 7, image 2 de 3 Google Pixel 2 Fingerprint Sensor Replacement: étape 7, image 3 de 3
    • Slide the pick around the bottom-left corner and along the bottom of the phone. Keep pick at a slight angle away from the screen to avoid damage to the OLED corners.
    • Take extra care not to insert the opening pick more than 9 mm to avoid damaging the OLED panel.
    Demander à FixBot
  8. Google Pixel 2 Fingerprint Sensor Replacement: étape 8, image 1 de 2 Google Pixel 2 Fingerprint Sensor Replacement: étape 8, image 2 de 2
    • Reinsert the pick at the top edge of the phone and gently pry up the display.
    • If the display doesn't readily lift, do some extra prying to separate the last of the adhesive. The adhesive near the upper speaker is thicker than other places.
    • Don't try to fully separate the display yet, as a fragile ribbon cable still connects it to the phone's motherboard.
    Demander à FixBot
  9. Google Pixel 2 Fingerprint Sensor Replacement: étape 9, image 1 de 2 Google Pixel 2 Fingerprint Sensor Replacement: étape 9, image 2 de 2
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    • Carefully lay the display down on top of the rear case as shown, making sure not to crease or tear the display ribbon cable.
    • Remove the two 4.0 mm T5 Torx screws securing the display cable bracket.
    Demander à FixBot
  10. Google Pixel 2 Fingerprint Sensor Replacement: étape 10, image 1 de 1
    • Remove the display cable bracket.
    Demander à FixBot
  11. Google Pixel 2 Fingerprint Sensor Replacement: étape 11, image 1 de 2 Google Pixel 2 Fingerprint Sensor Replacement: étape 11, image 2 de 2
    • Use the point of a spudger to lift the display cable connector up and out of its socket on the motherboard.
    • Avoid touching the motherboard with the tip of your spudger. The components surrounding the socket are fragile.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
    • During reassembly, pause here and replace the adhesive around the edges of the display.
    Demander à FixBot
  12. Google Pixel 2 Fingerprint Sensor Replacement, Midframe: étape 12, image 1 de 1
    • Apply a heated iOpener to the proximity sensor on the top edge of the midframe for two minutes to soften its adhesive.
    Demander à FixBot
  13. Google Pixel 2 Fingerprint Sensor Replacement: étape 13, image 1 de 2 Google Pixel 2 Fingerprint Sensor Replacement: étape 13, image 2 de 2
    • Slide the point of a spudger under the proximity sensor cable, starting from the side closest to the front-facing camera.
    • Gently lift the edge of the sensor cable until the sensor is perpendicular to the midframe.
    Demander à FixBot
  14. Google Pixel 2 Fingerprint Sensor Replacement: étape 14, image 1 de 1
    $19.95
    • Peel back the small piece of tape covering the screw below the earpiece speaker. Peel back any tape covering other screws as well.
    • Remove the following screws securing the midframe:
    • Eleven 3.7 mm Phillips screws
    • One 4 mm T5 Torx screw
    Demander à FixBot
  15. Google Pixel 2 Fingerprint Sensor Replacement: étape 15, image 1 de 2 Google Pixel 2 Fingerprint Sensor Replacement: étape 15, image 2 de 2
    • Insert an opening tool into the notch in the midframe near the hold button.
    • Pry the midframe up enough to create a gap between it and the phone case. The midframe cannot yet be completely removed.
    Demander à FixBot
  16. Google Pixel 2 Fingerprint Sensor Replacement: étape 16, image 1 de 3 Google Pixel 2 Fingerprint Sensor Replacement: étape 16, image 2 de 3 Google Pixel 2 Fingerprint Sensor Replacement: étape 16, image 3 de 3
    • Lift the midframe up starting from the bottom edge.
    • When the midframe starts to make about a 45° with the rest of the phone, lift the midframe straight up and away from the phone.
    • As you lift the midfame, carefully guide the proximity sensor through the small slot in the midframe.
    Demander à FixBot
  17. Google Pixel 2 Fingerprint Sensor Replacement, Battery Connector: étape 17, image 1 de 2 Google Pixel 2 Fingerprint Sensor Replacement, Battery Connector: étape 17, image 2 de 2
    • Use the flat end of a spudger to disconnect the battery connector.
    Demander à FixBot
  18. Google Pixel 2 Fingerprint Sensor Replacement, Battery: étape 18, image 1 de 2 Google Pixel 2 Fingerprint Sensor Replacement, Battery: étape 18, image 2 de 2
    • Use the flat end of a spudger to disconnect the charging assembly connector.
    Demander à FixBot
  19. Google Pixel 2 Fingerprint Sensor Replacement: étape 19, image 1 de 1
    • Fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply a few drops of alcohol under each corner of the battery. Give the alcohol a minute to weaken the battery adhesive.
    • Alternatively, apply a heated iOpener to the back of the phone over the battery for at least two minutes. Reheat and reapply the iOpener as needed until the battery adhesive is sufficiently weakened.
    Demander à FixBot
  20. Google Pixel 2 Fingerprint Sensor Replacement: étape 20, image 1 de 2 Google Pixel 2 Fingerprint Sensor Replacement: étape 20, image 2 de 2
    • Hold the charging assembly cable out of the way and insert an opening pick along the bottom edge of the battery.
    • Apply steady, even pressure to slowly lever the battery up and out of the phone.
    • Only pry from the center of the battery to avoid damaging the delicate ribbon cables beneath either side of the battery.
    • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • If you are having trouble, apply some more alcohol under the battery and try again.
    Demander à FixBot
  21. Google Pixel 2 Fingerprint Sensor Replacement: étape 21, image 1 de 2 Google Pixel 2 Fingerprint Sensor Replacement: étape 21, image 2 de 2
    Tesa 61395 Tape
    $8.95
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • To install a new battery:
    • Use a spudger to scrape away any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone, not directly onto the battery. The adhesive should not touch any of the cables under the battery.
    • Press the battery firmly into place for 20-30 seconds.
    Demander à FixBot
  22. Google Pixel 2 Fingerprint Sensor Replacement, Motherboard: étape 22, image 1 de 2 Google Pixel 2 Fingerprint Sensor Replacement, Motherboard: étape 22, image 2 de 2
    • use the flat end of a spudger to disconnect the charging assembly connector from the motherboard.
    Demander à FixBot
  23. Google Pixel 2 Fingerprint Sensor Replacement: étape 23, image 1 de 3 Google Pixel 2 Fingerprint Sensor Replacement: étape 23, image 2 de 3 Google Pixel 2 Fingerprint Sensor Replacement: étape 23, image 3 de 3
    • Insert a paperclip or SIM eject tool into the small hole on the left side of the phone and push until the SIM card tray pops out.
    • Remove the SIM card tray.
    Demander à FixBot
  24. Google Pixel 2 Fingerprint Sensor Replacement: étape 24, image 1 de 1
    • Remove the two 2.5 mm PH00 screws.
    Demander à FixBot
  25. Google Pixel 2 Fingerprint Sensor Replacement: étape 25, image 1 de 3 Google Pixel 2 Fingerprint Sensor Replacement: étape 25, image 2 de 3 Google Pixel 2 Fingerprint Sensor Replacement: étape 25, image 3 de 3
    • Disconnect two connectors at the bottom edge of the motherboard.
    Demander à FixBot
  26. Google Pixel 2 Fingerprint Sensor Replacement: étape 26, image 1 de 2 Google Pixel 2 Fingerprint Sensor Replacement: étape 26, image 2 de 2
    • Pry up the motherboard using a plastic opening tool.
    • Remove the motherboard.
    Demander à FixBot
  27. Google Pixel 2 Fingerprint Sensor Replacement: étape 27, image 1 de 3 Google Pixel 2 Fingerprint Sensor Replacement: étape 27, image 2 de 3 Google Pixel 2 Fingerprint Sensor Replacement: étape 27, image 3 de 3
    • Flip the motherboard over.
    • Disconnect the fingerprint sensor cable.
    • The motherboard is now completely detached from the phone.
    Demander à FixBot
  28. Google Pixel 2 Fingerprint Sensor Replacement, Fingerprint Sensor: étape 28, image 1 de 2 Google Pixel 2 Fingerprint Sensor Replacement, Fingerprint Sensor: étape 28, image 2 de 2
    • Flip the device over so that the display side is facing the ground.
    • Use your hand to push the fingerprint sensor down toward the inside of the phone.
    Demander à FixBot
  29. Google Pixel 2 Fingerprint Sensor Replacement: étape 29, image 1 de 2 Google Pixel 2 Fingerprint Sensor Replacement: étape 29, image 2 de 2
    • Flip the device over again so that the display side is facing up.
    • Remove the fingerprint sensor.
    Demander à FixBot
4 autres ont terminé cette réparation.
Taylor Sanders
Membre depuis le 01/24/18
530 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S18-G5, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S18-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G5
4 membres
23 tutoriels rédigés
1 commentaire de tutoriel
Replacing the fingerprint sensor. I’m a Medical Device Electronics Technician. Specifically electronic repairs. Everything I repair is designed to be repaired and I have the facilities at hand, to make professional repairs that are FDA certified processes. I’ve tried replacing displays, batteries, and now a fingerprint detector. Thing about most phones is they require heat to both open and re-seal. Think Ametek Hermetic Board sealers. Douglas sandwich sealers. My Pixel 2 finger print sensor got scratched and stopped working. For my Pixel I was unsucessful in reinstalling the display. I got it all back together and working . After 2 weeks the device stopped working reliably. The display peeled off and I was unable to get it to recognize touch. VERY sensitive repairs. It’s why they are assembled in Class 100 clean rooms. A piece of lint is all it takes to short a pixel.
Incredible they charge what they do for a device that cannot be repaired. The phone itself is a inegrated circuit. Insane.
William Hilow - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 46
Total : 8,124
