Aller au contenu principal
HP Compaq nc8430 RAM Replacement
bryan ingram
bryan ingram et 5 autres contributeurs
Dernière mise à jour le June 17, 2019
1 - 4 minutes
Facile
Détails manquants
This guide will show you how to remove the RAM from a HP Compaq nc8430.
Ce dont vous avez besoin
  1. HP Compaq nc8430 RAM Replacement, Battery: étape 1, image 1 de 1
    • Completely shut down the device and unplug any adapters and cords connected to the device.
    • Carefully flip the device over so that the bottom is facing up.
    • Slide both of the latches to the left.
  2. HP Compaq nc8430 RAM Replacement: étape 2, image 1 de 1
    • Slide up against the three lines the battery has.
  3. HP Compaq nc8430 RAM Replacement: étape 3, image 1 de 1
    • Slide the battery up and away from the laptop.
    • Slowly remove the battery to prevent any connectors from getting damaged.
  4. HP Compaq nc8430 RAM Replacement, Remove RAM cover: étape 4, image 1 de 1
    • Completely shut down the device and unplug any adapters and chords that are connected.
  5. HP Compaq nc8430 RAM Replacement: étape 5, image 1 de 1
    • Use a screwdriver to remove the single screw on the covering located on the back of the laptop.
  6. HP Compaq nc8430 RAM Replacement, Locate RAM: étape 6, image 1 de 1
    • Locate the RAM after you remove the covering.
  7. HP Compaq nc8430 RAM Replacement, Push clamps aside: étape 7, image 1 de 1
    • Use fingers or tools to press the clamps that hold the RAM in to the side.
  8. HP Compaq nc8430 RAM Replacement, Pull RAM up to remove: étape 8, image 1 de 1
    • Place your fingers firmly on the RAM and pull it up.
  9. HP Compaq nc8430 RAM Replacement, Remove RAM: étape 9, image 1 de 1
    • Place fingers firmly on RAM and pull it to remove it.
bryan ingram
Membre depuis le 03/27/17
101 Réputation
1 tutoriel rédigé
Équipe
Texas Tech, Team S13-G4, Bennett Spring 2017 Membre de l'équipe Texas Tech, Team S13-G4, Bennett Spring 2017
TTU-BENNETT-S17S13G4
5 membres
5 tutoriels rédigés
1 commentaire de tutoriel
umm fine, except there is another module under the keyboard , rather an important fact to be overlooking
bari - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 22
Total : 781
