Aller au contenu principal
HP Envy TouchSmart 4-1215dx Display Replacement
Isaac York
Isaac York et 2 autres contributeurs
Dernière mise à jour le May 25, 2022
10 - 15 minutes
Modérée
This is a guide for replacing the display on an HP Envy TouchSmart 4-1215dx. The display outputs text and graphics that the computer makes. If you are experiencing distorted images, you may want to replace your display. Before replacing, look at the troubleshooting page to see if your problem can be fixed without replacing: HP Envy Touchsmart 4-1215dx Troubleshooting. If your display is shattered, you should cover it with tape before removing it.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. HP Envy TouchSmart 4-1215dx Display Replacement, Display: étape 1, image 1 de 1
    • Remove both 3 mm screws at the bottom of the display using a Phillips #0 screwdriver.
  2. HP Envy TouchSmart 4-1215dx Display Replacement: étape 2, image 1 de 2 HP Envy TouchSmart 4-1215dx Display Replacement: étape 2, image 2 de 2
    • Using an iFixit opening tool, pry the screen from the back panel.
    • Remove the back panel.
  3. HP Envy TouchSmart 4-1215dx Display Replacement: étape 3, image 1 de 1
    • Close the laptop so the front is facing you.
    • Remove the four 3 mm screws from the two brackets at the front using a Phillips #0 screwdriver.
    • Remove the brackets.
  4. HP Envy TouchSmart 4-1215dx Display Replacement: étape 4, image 1 de 3 HP Envy TouchSmart 4-1215dx Display Replacement: étape 4, image 2 de 3 HP Envy TouchSmart 4-1215dx Display Replacement: étape 4, image 3 de 3
    • Remove the 3 mm screws from the back brackets using a Phillips #0 screwdriver.
    • Remove the 1 mm screws with a Phillips #00 screwdriver.
    • Lift up the display until the brackets are sticking straight up.
  5. HP Envy TouchSmart 4-1215dx Display Replacement: étape 5, image 1 de 1
    • Peel off the aluminum tape located at the top of the display.
  6. HP Envy TouchSmart 4-1215dx Display Replacement: étape 6, image 1 de 2 HP Envy TouchSmart 4-1215dx Display Replacement: étape 6, image 2 de 2
    • Disconnect the ribbon cable and peel off the connected tape from the display.
  7. HP Envy TouchSmart 4-1215dx Display Replacement: étape 7, image 1 de 2 HP Envy TouchSmart 4-1215dx Display Replacement: étape 7, image 2 de 2
    • Lift the display up separately from the screen.
    • Peel off the orange tape at the bottom of the display connecting to the laptop.
  8. HP Envy TouchSmart 4-1215dx Display Replacement: étape 8, image 1 de 1
    • Lift up the display.
    • If your display is cracked or shattered, you should tape up the effected parts in order to avoid injury.
Isaac York
Membre depuis le 02/08/22
157 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 296
