Aller au contenu principal
HP Envy x360 m6-aq105dx Battery Replacement
Ryan Blazier
Ryan Blazier et 4 autres contributeurs
Dernière mise à jour le June 3, 2020
25 - 30 minutes
Modérée
Meilleure introduction
A faulty battery results in no power transfer to the laptop, meaning it wont turn on or charge. This guide will instruct on how to replace the battery to your HP Envy.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. HP Envy x360 m6-aq105dx Battery Replacement, Back Cover: étape 1, image 1 de 1
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx Battery Replacement: étape 2, image 1 de 1
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
  3. HP Envy x360 m6-aq105dx Battery Replacement, Battery: étape 3, image 1 de 1
    • Attach the grounding bracelet's clip to the frame of the laptop, then put on the grounding bracelet.
    • Remove the six 4.6mm screws securing the battery using the Phillips #0 screwdriver.
  4. HP Envy x360 m6-aq105dx Battery Replacement: étape 4, image 1 de 1
    • Disconnect the power supply cable connected to the motherboard.
  5. HP Envy x360 m6-aq105dx Battery Replacement: étape 5, image 1 de 2 HP Envy x360 m6-aq105dx Battery Replacement: étape 5, image 2 de 2
    • Remove the battery from the device.
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 1,354
