Aller au contenu principal
HP Pavilion 11 x360 Keyboard Replacement
Natalie
Natalie et 4 autres contributeurs
Dernière mise à jour le December 25, 2023
30 - 45 minutes
Modérée
Étapes manquantes
Découpez pour améliorer
Make sure your device is completely powered off and unplugged from any power source before beginning.
Ce dont vous avez besoin
Outils
  • Phillips #0 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Afficher plus…
  1. HP Pavilion 11 x360 Keyboard Replacement, Remove Screws: étape 1, image 1 de 2 HP Pavilion 11 x360 Keyboard Replacement, Remove Screws: étape 1, image 2 de 2
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Keyboard Replacement, Remove Backing: étape 2, image 1 de 3 HP Pavilion 11 x360 Keyboard Replacement, Remove Backing: étape 2, image 2 de 3 HP Pavilion 11 x360 Keyboard Replacement, Remove Backing: étape 2, image 3 de 3
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Keyboard Replacement, Detach Cable: étape 3, image 1 de 2 HP Pavilion 11 x360 Keyboard Replacement, Detach Cable: étape 3, image 2 de 2
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Keyboard Replacement, Battery: étape 4, image 1 de 1
    • Remove the four 6mm screws from the battery with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Keyboard Replacement: étape 5, image 1 de 3 HP Pavilion 11 x360 Keyboard Replacement: étape 5, image 2 de 3 HP Pavilion 11 x360 Keyboard Replacement: étape 5, image 3 de 3
    • Use the spudger to pry up the blue/white speaker wires that are routed beside the battery.
  6. HP Pavilion 11 x360 Keyboard Replacement: étape 6, image 1 de 2 HP Pavilion 11 x360 Keyboard Replacement: étape 6, image 2 de 2
    • Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
  7. HP Pavilion 11 x360 Keyboard Replacement: étape 7, image 1 de 2 HP Pavilion 11 x360 Keyboard Replacement: étape 7, image 2 de 2
    • Remove the battery.
    directions great, but i cant find a place to buy it. not even on the HP we site. Help please
    dwest5555 - Réponse
    I found the battery on Amazon
    JoAnne O'Donnell - Réponse
    Könnten Sie mir bitte sagen, was für ein Akku verwendet worden ist.
    das wäre für mich sehr hilfreich.
    Vielen Dank
    Junior Kuchi - Réponse
  8. HP Pavilion 11 x360 Keyboard Replacement, Remove Screws: étape 8, image 1 de 1
    • Remove the two 3mm screws with the PH0 screwdriver.
  9. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Cable: étape 9, image 1 de 2 HP Pavilion 11 x360 Keyboard Replacement, Disconnect Cable: étape 9, image 2 de 2
    • Use your fingernails to slowly loosen the fan connection cable.
    • After the cable is slightly pulled from the connection, grab the cable and pull it outwards.
  10. HP Pavilion 11 x360 Keyboard Replacement, Remove Hard Drive: étape 10, image 1 de 2 HP Pavilion 11 x360 Keyboard Replacement, Remove Hard Drive: étape 10, image 2 de 2
    • Remove the three 3mm screws using the PH0 screwdriver.
    • Pull the hard drive slightly away from the connection to easily disconnect the hard drive cable from the motherboard.
    • Remove the hard drive.
  11. HP Pavilion 11 x360 Keyboard Replacement: étape 11, image 1 de 1
    • Remove the four 3mm screws using the PH0 screwdriver.
  12. HP Pavilion 11 x360 Keyboard Replacement: étape 12, image 1 de 3 HP Pavilion 11 x360 Keyboard Replacement: étape 12, image 2 de 3 HP Pavilion 11 x360 Keyboard Replacement: étape 12, image 3 de 3
    • Remove the two screws from the metal hinge on the power button side using the PH0 screwdriver.
    • One silver 4mm screw
    • One black 5mm screw
    • Lift up the hinge to remove the metal bracket underneath.
  13. HP Pavilion 11 x360 Keyboard Replacement: étape 13, image 1 de 3 HP Pavilion 11 x360 Keyboard Replacement: étape 13, image 2 de 3 HP Pavilion 11 x360 Keyboard Replacement: étape 13, image 3 de 3
    • Remove one 3mm screw using the PH0 screwdriver from the metal hinge located on the power connector side of the computer.
    • Lift up the hinge with some force to remove the metal bracket underneath.
  14. HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Wireless Card: étape 14, image 1 de 2 HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Wireless Card: étape 14, image 2 de 2
    • Unscrew the two 3mm screws with the PH0 screwdriver.
    • Pull the wireless card out of its port to disconnect it from the motherboard.
  15. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Keyboard Cable: étape 15, image 1 de 3 HP Pavilion 11 x360 Keyboard Replacement, Disconnect Keyboard Cable: étape 15, image 2 de 3 HP Pavilion 11 x360 Keyboard Replacement, Disconnect Keyboard Cable: étape 15, image 3 de 3
    • Push the black tab away from the hinge of the laptop.
    • After the black tab has been flipped, pull out the blue cable to disconnect the keyboard cable.
  16. HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Webcam Cable: étape 16, image 1 de 2 HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Webcam Cable: étape 16, image 2 de 2
    • Pull horizontally toward the hinge of the laptop to disconnect the webcam cable.
  17. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Display Cable: étape 17, image 1 de 3 HP Pavilion 11 x360 Keyboard Replacement, Disconnect Display Cable: étape 17, image 2 de 3 HP Pavilion 11 x360 Keyboard Replacement, Disconnect Display Cable: étape 17, image 3 de 3
    • Pull up on the black tabs to disconnect the display cable.
  18. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Power Button Board: étape 18, image 1 de 2 HP Pavilion 11 x360 Keyboard Replacement, Disconnect Power Button Board: étape 18, image 2 de 2
    • Pull the cable horizontally away from the motherboard to disconnect the power button board cable.
  19. HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Power Connector Cable: étape 19, image 1 de 2 HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Power Connector Cable: étape 19, image 2 de 2
    • Pull the cable horizontally away from the motherboard to disconnect the power connector cable.
  20. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Speaker Cable: étape 20, image 1 de 2 HP Pavilion 11 x360 Keyboard Replacement, Disconnect Speaker Cable: étape 20, image 2 de 2
    • Pull the cable horizontally away from the motherboard to disconnect the speaker cable.
  21. HP Pavilion 11 x360 Keyboard Replacement, Remove Touch Pad Cable: étape 21, image 1 de 3 HP Pavilion 11 x360 Keyboard Replacement, Remove Touch Pad Cable: étape 21, image 2 de 3 HP Pavilion 11 x360 Keyboard Replacement, Remove Touch Pad Cable: étape 21, image 3 de 3
    • Push the white tab up toward the hinge of the laptop.
    • Disconnect touch pad cable by pulling up and away from the motherboard.
  22. HP Pavilion 11 x360 Keyboard Replacement: étape 22, image 1 de 2 HP Pavilion 11 x360 Keyboard Replacement: étape 22, image 2 de 2
    • Lift up to remove the motherboard.
  23. HP Pavilion 11 x360 Keyboard Replacement: étape 23, image 1 de 3 HP Pavilion 11 x360 Keyboard Replacement: étape 23, image 2 de 3 HP Pavilion 11 x360 Keyboard Replacement: étape 23, image 3 de 3
    • Push outwards on the two black tabs to pop the RAM up.
  24. HP Pavilion 11 x360 Keyboard Replacement: étape 24, image 1 de 1
    • Remove the RAM.
  25. HP Pavilion 11 x360 Keyboard Replacement: étape 25, image 1 de 2 HP Pavilion 11 x360 Keyboard Replacement: étape 25, image 2 de 2
    • Lift up the heat sink to remove it from the motherboard.
  26. HP Pavilion 11 x360 Keyboard Replacement, Detach Keyboard: étape 26, image 1 de 2 HP Pavilion 11 x360 Keyboard Replacement, Detach Keyboard: étape 26, image 2 de 2
    • Remove the fifteen 3mm screws connected directly to the keyboard using the PH0 screwdriver.
    • Remove the 3mm screw under the keyboard cable using the PH0 screwdriver.
  27. HP Pavilion 11 x360 Keyboard Replacement, Remove Power Button Board: étape 27, image 1 de 1
    • Remove the two 3mm screws attached to the power button board.
    • Lift out power button board.
  28. HP Pavilion 11 x360 Keyboard Replacement: étape 28, image 1 de 3 HP Pavilion 11 x360 Keyboard Replacement: étape 28, image 2 de 3 HP Pavilion 11 x360 Keyboard Replacement: étape 28, image 3 de 3
    • Lift keyboard out.
9 autres ont terminé cette réparation.
Natalie
Membre depuis le 01/22/15
937 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 19-9, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 19-9, Maness Winter 2015
CPSU-MANESS-W15S19G9
4 membres
12 tutoriels rédigés
3 commentaires de tutoriel
Best guide. I just ordered keypad for my laptop. Thank you very much for sharing this!
ashumicro - Réponse
I just replaced my keyboard and everything was exactly like the guide. Worked perfectly.
Robert Young - Réponse
Hello, I'm the computer tech for a school, we have about 500 HP Probook x360 11 G1 EE, and often the key pop out and the hinge are broken, not the key. Where can I buy a bunch (like 25+) of hinges only.
XAVIER FRETARD - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 30
Total : 13,871
