Aller au contenu principal
How to Disconnect the Battery in the Xiaomi Poco X3 Pro
Dominik Schnabelrauch
Dominik Schnabelrauch et un autre contributeur
Dernière mise à jour le October 7, 2024
25 - 35 minutes
Modérée
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
This is a prerequisite guide! This guide is part of another procedure and is not meant to be used alone.
Use this guide to disconnect the battery in the Xiaomi Poco X3 Pro.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Heat the back cover: étape 1, image 1 de 1
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Insert an opening pick: étape 2, image 1 de 3 How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Insert an opening pick: étape 2, image 2 de 3 How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Insert an opening pick: étape 2, image 3 de 3
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Slice the adhesive: étape 3, image 1 de 2 How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Slice the adhesive: étape 3, image 2 de 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
  4. How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Slice the adhesive: étape 4, image 1 de 3 How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Slice the adhesive: étape 4, image 2 de 3 How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Slice the adhesive: étape 4, image 3 de 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. How to Disconnect the Battery in the Xiaomi Poco X3 Pro: étape 5, image 1 de 2 How to Disconnect the Battery in the Xiaomi Poco X3 Pro: étape 5, image 2 de 2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. How to Disconnect the Battery in the Xiaomi Poco X3 Pro: étape 6, image 1 de 2 How to Disconnect the Battery in the Xiaomi Poco X3 Pro: étape 6, image 2 de 2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
  7. How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Remove the back cover: étape 7, image 1 de 2 How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Remove the back cover: étape 7, image 2 de 2
    • Remove the back cover.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  8. How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Unscrew the motherboard cover screws: étape 8, image 1 de 1
    • Use a Phillips screwdriver of the correct size to remove the eleven 3.9 mm-long screws securing the motherboard cover.
  9. How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Pry up the motherboard cover: étape 9, image 1 de 3 How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Pry up the motherboard cover: étape 9, image 2 de 3 How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Pry up the motherboard cover: étape 9, image 3 de 3
    • Insert the tip of an opening pick underneath the bottom right edge of the motherboard cover.
    • Slide the opening pick along the right edge of the motherboard cover to unhinge the plastic clips and pry it up.
    • Insert the opening pick underneath the top edge of the motherboard cover and pry it up.
  10. How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Remove the motherboard cover: étape 10, image 1 de 2 How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Remove the motherboard cover: étape 10, image 2 de 2
    • Remove the motherboard cover.
  11. How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Disconnect the battery cable: étape 11, image 1 de 2 How to Disconnect the Battery in the Xiaomi Poco X3 Pro, Disconnect the battery cable: étape 11, image 2 de 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Membre depuis le 11/23/16
232 450 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
121 membres
19 996 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 73
