Aller au contenu principal
How to Replace a Skateboard Deck
Dylan Norris
Dylan Norris et un autre contributeur
Dernière mise à jour le December 21, 2022
15 - 30 minutes
Facile
If your deck is warped, broken, or just need style change, then use this guide to replace your deck.
The deck is the part of the board that you stand on, and with time it is subject to wear and tear. Sometimes, it just snaps in half on you after very heavy and intense use.
Be sure to first obtain the new deck, and purchase grip to go with it. Decks do not come with grip pre-applied, which we will cover how to apply it in this guide.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. How to Replace a Skateboard Deck, Deck: étape 1, image 1 de 1
    • Use the 3/8" socket to take off the nut
    • Use the phillips side to hold the screw in place.
    • Remove the nut
    • Repeat for all four nuts on the truck
    • Repeat for the second truck
  2. How to Replace a Skateboard Deck: étape 2, image 1 de 2 How to Replace a Skateboard Deck: étape 2, image 2 de 2
    • Remove both trucks from the board
    • Remove all 8 screws
  3. How to Replace a Skateboard Deck: étape 3, image 1 de 3 How to Replace a Skateboard Deck: étape 3, image 2 de 3 How to Replace a Skateboard Deck: étape 3, image 3 de 3
    • Line up the grip with the board
    • Ensure it covers the entirety of the board and hangs over the edge
    • Peel the back off at one end enough to reveal the sticky side.
    • Expose about four inches
    • Attach the peeled side to one end of the board
    • Press the grip onto the board slowly and work your way across the board
    • Ensure that there is no air bubbles forming when applying the grip
  4. How to Replace a Skateboard Deck: étape 4, image 1 de 2 How to Replace a Skateboard Deck: étape 4, image 2 de 2
    • Use the phillips head screwdriver to trace the edge of the board
    • Ensure it can be seen all the way around the board
  5. How to Replace a Skateboard Deck: étape 5, image 1 de 1
    • Trim the grip along the trace you made with the box cutter
    • Use long and smooth motions for straight trims
    • Trim up the jagged edges left on the grip on the edge of the board
  6. How to Replace a Skateboard Deck: étape 6, image 1 de 1
    • Sand the edges with the left over grip
    • This is to ensure the grip fully applies to the board
  7. How to Replace a Skateboard Deck: étape 7, image 1 de 2 How to Replace a Skateboard Deck: étape 7, image 2 de 2
    • Poke a hole with the screw from the bottom of the deck
    • Remove the screw
    • Insert it through the top on the deck
    • Repeat for all 4 holes
    • Repeat on the opposite side with the other truck
  8. How to Replace a Skateboard Deck: étape 8, image 1 de 3 How to Replace a Skateboard Deck: étape 8, image 2 de 3 How to Replace a Skateboard Deck: étape 8, image 3 de 3
    • Use the 3/8" socket to screw on the nut
    • The hangar should face outwards
    • Tighten them until they're snug
    • Overtightening can damage the deck
Ligne d'arrivée
Dylan Norris
Membre depuis le 10/06/22
157 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 28
Total : 814
