Aller au contenu principal
How to open the Huawei Watch GT 2e
Tobias Isakeit
Tobias Isakeit et 3 autres contributeurs
Dernière mise à jour le May 16, 2024
15 - 25 minutes
Modérée
Use this guide to open the Huawei Watch GT2e and remove the rear assembly.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. How to open the Huawei Watch GT 2e, Turn off the watch: étape 1, image 1 de 2 How to open the Huawei Watch GT 2e, Turn off the watch: étape 1, image 2 de 2
    • Turn off the watch:
    • Press and hold the top button for >3 sec.
    • Tap "Power off".
    • Push the small sliding nub on one of the watch band pins inwards toward the center of the watch band.
    • While holding the nub in, pull one side of the pin out of its recess on the watch housing, then the other side.
    • Remove the band.
    • Repeat this process to remove the second band.
  2. How to open the Huawei Watch GT 2e, Remove the four rear screws: étape 3, image 1 de 1
    • Remove the four 3.5 mm-long T3 Torx screws on the back of the watch.
  3. How to open the Huawei Watch GT 2e, Open a small gap: étape 4, image 1 de 3 How to open the Huawei Watch GT 2e, Open a small gap: étape 4, image 2 de 3 How to open the Huawei Watch GT 2e, Open a small gap: étape 4, image 3 de 3
    • Place the point of a spudger in the small hole on the side of the rear case.
    • Use the spudger to push the rear case away from the housing to create a small gap. Use steady force to separate the two parts.
    • Steady the rear case with a finger to avoid it suddenly popping open and damaging the flex cable.
    • Don’t open the rear case all the way just yet. It is still connected to the motherboard with a thin flex cable.
  4. How to open the Huawei Watch GT 2e, Flip the rear case open: étape 5, image 1 de 3 How to open the Huawei Watch GT 2e, Flip the rear case open: étape 5, image 2 de 3 How to open the Huawei Watch GT 2e, Flip the rear case open: étape 5, image 3 de 3
    • Flip the rear case assembly open towards the buttons to access the interconnect flex cable connector.
  5. How to open the Huawei Watch GT 2e, Remove the bracket screw: étape 6, image 1 de 1
    Outil utilisé dans cette étape :
    $3.99
    • Remove the 2.5 mm-long Phillips screw securing the interconnect cable bracket.
    • When re-assembling you might need a pair of pointy angled tweezers to position the screw since they are non-ferrous and therefore don’t stick to the magnetic bit.
  6. How to open the Huawei Watch GT 2e, Remove the bracket: étape 7, image 1 de 3 How to open the Huawei Watch GT 2e, Remove the bracket: étape 7, image 2 de 3 How to open the Huawei Watch GT 2e, Remove the bracket: étape 7, image 3 de 3
    • Use a pair of tweezers to slide the interconnect cable bracket down and left to unlatch it.
    • Remove the interconnect cable bracket.
    • For reassembly make sure to slide the bracket into place from bottom left towards top right to engage the small latch.
  7. How to open the Huawei Watch GT 2e, Unplug the flex cable: étape 8, image 1 de 3 How to open the Huawei Watch GT 2e, Unplug the flex cable: étape 8, image 2 de 3 How to open the Huawei Watch GT 2e, Unplug the flex cable: étape 8, image 3 de 3
    • Use the flat end of a spudger to pry up and unplug the interconnect cable.
    • Remove the rear case assembly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answer Community for help.
3 autres ont terminé cette réparation.
Tobias Isakeit
Membre depuis le 03/31/14
124 417 Réputation
189 tutoriels rédigés
Équipe
Tobias Isakeit - Repairability Engineer Membre de l'équipe Tobias Isakeit - Repairability Engineer
Business
1 membre
1 132 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 64
Total : 3,139
