Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to refurbish and clean longboard bushings
Matthew Columbres
Matthew Columbres et 3 autres contributeurs
Dernière mise à jour le 9 avr. 2019
20 minutes
Facile
In this guide we will learn how to refurbish and clean old longboard bushings that just don't work like they used to. Unresponsive bushings can be potentially dangerous when skating, as the bushings determine how the board turns. Through the use of boiling water, soap, and this guide, your longboard bushings will seem like they're brand new.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. How to refurbish and clean longboard bushings, How to refurbish and clean longboard bushings: étape 1, image 1 de 2 How to refurbish and clean longboard bushings, How to refurbish and clean longboard bushings: étape 1, image 2 de 2
    • Start by placing your board on its top so that you can access the trucks.
    • Use an adjustable wrench to remove the large nut that is screwed onto the end of the kingpin.
  2. How to refurbish and clean longboard bushings: étape 2, image 1 de 3 How to refurbish and clean longboard bushings: étape 2, image 2 de 3 How to refurbish and clean longboard bushings: étape 2, image 3 de 3
    • Take apart the trucks by removing the parts in this order: washer #1, bushing #1, metal hangar, bushing #2, washer #2
    • To remove the hanger, wiggle it off of the kingpin (large bolt), then lift it out of the pivot cup.
    • Make sure you remember the order of the parts! Take a picture if you need to, or simply refer to the other side of the board for the correct truck setup.
  3. How to refurbish and clean longboard bushings: étape 3, image 1 de 2 How to refurbish and clean longboard bushings: étape 3, image 2 de 2
    • Using pliers (needle nose would work best), take out the small pivot cup where the metal hangar was resting.
    • Place all of the pieces aside. Make sure to not lose any, as one missing piece means your board can't be put back together.
  4. How to refurbish and clean longboard bushings: étape 4, image 1 de 2 How to refurbish and clean longboard bushings: étape 4, image 2 de 2
    • Apply a small amount of rubbing alcohol on a cloth or sheet of paper towel. Clean the pivot cup and bushings.
    • Rinse the pivot cup and bushings by running the items through hot water.
  5. How to refurbish and clean longboard bushings: étape 5, image 1 de 2 How to refurbish and clean longboard bushings: étape 5, image 2 de 2
    • Take a small pot and bring a moderate amount of water to a rolling boil.
    • Place the bushings in the boiling water and cover the pot. Boil the bushings for 10-15 minutes.
    • Boiling water is hot! Make sure to be careful when putting in the bushings.
  6. How to refurbish and clean longboard bushings: étape 6, image 1 de 1
    • Using the pliers, take the bushings out of the pot.
    • If you are not comfortable with the softness just yet, boil the bushings for 5 more minutes.
    • Let the bushings cool for 2 minutes.
  7. How to refurbish and clean longboard bushings: étape 7, image 1 de 3 How to refurbish and clean longboard bushings: étape 7, image 2 de 3 How to refurbish and clean longboard bushings: étape 7, image 3 de 3
    • Take the edge of a soap bar and rub the bottom and top of the bushings until a film of soap is visible.
    • Using a knife, cut small soap shavings and place a small amount in the pivot cup.
  8. How to refurbish and clean longboard bushings: étape 8, image 1 de 3 How to refurbish and clean longboard bushings: étape 8, image 2 de 3 How to refurbish and clean longboard bushings: étape 8, image 3 de 3
    • Reassemble the trucks by first placing the pivot cup back in its hole
    • Place the washers, bushings, and hanger on the large bolt, and then tighten the nut last.
  9. How to refurbish and clean longboard bushings: étape 9, image 1 de 2 How to refurbish and clean longboard bushings: étape 9, image 2 de 2
    • Once the trucks have been reassembled, step on the board and test the turning sensitivity.
    • If turning is hard or requires you to lean too much, loosen the nut.
    • If turning is too loose and not stable, tighten the nut.
    • You have successfully tuned your longboard with your "new" bushings and it's ready to ride!
Now you're all set to ride your longboard with your "new" bushings!
Équipez-vous pour vos futures réparations
Voir tous les produits
Matthew Columbres
Membre depuis le 09/29/15
101 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 14-1, Green Fall 2015 Membre de l'équipe Cal Poly, Team 14-1, Green Fall 2015
CPSU-GREEN-F15S14G1
4 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 25
Total : 6,728
