Introduction
Sometimes the button switches on your JBL Charge 3 can wear out or get dirt in them causing one or more buttons to not work. Luckily the buttons are easy to clean once the cover is removed.
Tools
Parts
No parts specified.
Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
Repeat this process for all four edges of the front cover.
Use your plastic opening tool to pry around the edges of the button cover. This will begin to separate the adhesive from the cover.
Peel away the button cover with your hand once you have enough separated from the speaker housing to grab.
7 other people completed this guide.
