Aller au contenu principal
JBL Pulse 3 LED Light Display Replacement
Kaitlyn Greenfield
Kaitlyn Greenfield et 2 autres contributeurs
Dernière mise à jour le May 7, 2024
15 - 20 minutes
Modérée
Nécessite plus d'images
The LED light display is located on the inside of the JBL Pulse 3, under the outside casing. It LED light display is lined with LED light strips along the circular base.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. JBL Pulse 3 LED Light Display Replacement, Speaker Grill: étape 1, image 1 de 1
    • Lay the JBL Pulse 3 on its side as shown in the picture.
    • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
  2. JBL Pulse 3 LED Light Display Replacement: étape 2, image 1 de 1
    • Repeat step 1 for bottom right corner of speaker grill.
  3. JBL Pulse 3 LED Light Display Replacement: étape 3, image 1 de 2 JBL Pulse 3 LED Light Display Replacement: étape 3, image 2 de 2
    • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
    • Lift and pull straight out to pull grill off the posts.
    • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
  4. JBL Pulse 3 LED Light Display Replacement, Outside Casing: étape 5, image 1 de 2 JBL Pulse 3 LED Light Display Replacement, Outside Casing: étape 5, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
    #00 not required, successfully opened with PH#1
    Stephen Hoefler - Réponse
  5. JBL Pulse 3 LED Light Display Replacement: étape 6, image 1 de 2 JBL Pulse 3 LED Light Display Replacement: étape 6, image 2 de 2
    • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
    Ca I Specifically buy the top ring
    Julian Cruz - Réponse
    I've the same concern as the comment above, can I buy the top ring separately?
    Yousef - Réponse
    Opening is not as simple as demonstrated in Step 6. I have followed everything through, am I missing something?
    Kusala Kumsinda - Réponse
    Is there any other place to get this part? It doesnt ship to the UK
    Amelia - Réponse
  6. JBL Pulse 3 LED Light Display Replacement: étape 7, image 1 de 2 JBL Pulse 3 LED Light Display Replacement: étape 7, image 2 de 2
    • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
  7. JBL Pulse 3 LED Light Display Replacement: étape 8, image 1 de 1
    • Pull off the top disc of the JBL Pulse 3.
  8. JBL Pulse 3 LED Light Display Replacement: étape 9, image 1 de 2 JBL Pulse 3 LED Light Display Replacement: étape 9, image 2 de 2
    • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
    This phase could be difficult. Try to “twist” the speaker to have a little gap between both parts and insert gently a screwdriver or opening toile to spread the gap.
    Richard Devos - Réponse
  9. JBL Pulse 3 LED Light Display Replacement: étape 10, image 1 de 2 JBL Pulse 3 LED Light Display Replacement: étape 10, image 2 de 2
    • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
  10. JBL Pulse 3 LED Light Display Replacement: étape 11, image 1 de 1
    • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
  11. JBL Pulse 3 LED Light Display Replacement, LED Light Display: étape 12, image 1 de 3 JBL Pulse 3 LED Light Display Replacement, LED Light Display: étape 12, image 2 de 3 JBL Pulse 3 LED Light Display Replacement, LED Light Display: étape 12, image 3 de 3
    • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
    • Pull the LED light display off of the JBL Pulse 3 base.
  12. JBL Pulse 3 LED Light Display Replacement: étape 13, image 1 de 2 JBL Pulse 3 LED Light Display Replacement: étape 13, image 2 de 2
    Outil utilisé dans cette étape :
    • Use tweezers to pull the five connections off of the LED light display.
    up to step 13, the battery replacement steps are the same.
    From step 14 the steps change.
    Very good instructions for changing the battery in the jbl pulse 3 can be found here:
    https://www.youtube.com/watch?v=MpznDgxg...
    Mike Miker - Réponse
3 autres ont terminé cette réparation.
Kaitlyn Greenfield
Membre depuis le 09/20/18
1 188 Réputation
6 tutoriels rédigés
4 commentaires de tutoriel
Hello,I really need some code to show me how to initialize and LED display and how to output data from it.Any help is much appreciated.
Osama Siddiq - Réponse
Wow jbl
Gyyzhuahyz8yus
Majd Tom - Réponse
Where to buy the leds?
mj.viana1993 - Réponse
Hello i need an assitance in a LED screen manufacturing
volkanoo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 48
Total : 3,365
