LG G5 Front Panel Assembly
Introduction
Passez à l'étape 1Use this guide to remove your LG G5's front panel assembly. This involves separating the screen from the body of the phone. If you are trying to replace any components within the LG G5, you'll need to follow this guide first!
Ce dont vous avez besoin
While holding the battery release button, pull the bottom end of the phone out of the body.
Insert the plastic opening tool into the seam between the glass screen and the metal body.
Pry the glass from the body only a slight amount.
Insert the Spudger into the now open space between the body and screen.
Push inward to separate the screen even more.
Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
My LCD started to let loose using this way to saparate the top and bottom of the phone.
I used a guitar pick and slided it from the bottom to the top like the dude in this video: https://www.youtube.com/watch?v=XV10zyw8...
Didn’t had to use a lot of force this way, and my screen almost didn’t bend !
Yep! I did it also with this method. Wayy better and easier ;)
I found it easier to run the tool or a pick along the sides, and then sort of hinge the thing open at the top rather than running completely around the screen. It gets a little dicey where the glass starts to curve.
Now you can access all the inner components of the phone!
32 autres ont terminé cette réparation.
4 commentaires de tutoriel
quickest 50 bucks i ever made, lol. Thanks for having the guide up.
Love this phone... So MODULAR! Thanks for the guide.. Had to double-check when I was pulling it apart.. almost seemed too easy.
