Aller au contenu principal
Lenovo ThinkPad T480 LCD Screen Replacement
Sarah Westberg
Sarah Westberg et un autre contributeur
Dernière mise à jour le August 25, 2023
30 minutes - 1 heure
Difficile
If you need to replace the LCD screen of your Lenovo ThinkPad T480, follow this guide. The LCD screen or liquid crystal display is a type of flat-panel display. It uses liquid crystal film between glass plates that when voltage is applied its optical properties change and images are displayed or hidden.
If damage or failure occurs you may notice missing pixels, the color could be off, or the screen could crack if it is dropped or sustains a fall.
Prior to starting this repair, be sure to disable the internal battery, turn off the device, and unplug it from the charging cable.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Lenovo ThinkPad T480 LCD Screen Replacement, External Battery: étape 1, image 1 de 2 Lenovo ThinkPad T480 LCD Screen Replacement, External Battery: étape 1, image 2 de 2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 LCD Screen Replacement: étape 2, image 1 de 3 Lenovo ThinkPad T480 LCD Screen Replacement: étape 2, image 2 de 3 Lenovo ThinkPad T480 LCD Screen Replacement: étape 2, image 3 de 3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 LCD Screen Replacement, Back Cover: étape 3, image 1 de 2 Lenovo ThinkPad T480 LCD Screen Replacement, Back Cover: étape 3, image 2 de 2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 LCD Screen Replacement: étape 4, image 1 de 3 Lenovo ThinkPad T480 LCD Screen Replacement: étape 4, image 2 de 3 Lenovo ThinkPad T480 LCD Screen Replacement: étape 4, image 3 de 3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
  5. Lenovo ThinkPad T480 LCD Screen Replacement, Internal Battery: étape 5, image 1 de 2 Lenovo ThinkPad T480 LCD Screen Replacement, Internal Battery: étape 5, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the two 4.6 mm screws that secure the internal battery to the frame.
  6. Lenovo ThinkPad T480 LCD Screen Replacement: étape 6, image 1 de 3 Lenovo ThinkPad T480 LCD Screen Replacement: étape 6, image 2 de 3 Lenovo ThinkPad T480 LCD Screen Replacement: étape 6, image 3 de 3
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 LCD Screen Replacement: étape 7, image 1 de 2 Lenovo ThinkPad T480 LCD Screen Replacement: étape 7, image 2 de 2
    • Lift the battery straight out of its recess and remove it.
    • If the battery is difficult to remove from the recess, use a nylon spudger to gently lift it on one edge, making it easier to grasp and remove by hand.
    • To prevent damage or potential fire, do not bend or flex the battery. Only use a plastic spudger and avoid any sharp tools that could puncture the battery.
  8. Lenovo ThinkPad T480 LCD Screen Replacement, LCD Assembly: étape 8, image 1 de 2 Lenovo ThinkPad T480 LCD Screen Replacement, LCD Assembly: étape 8, image 2 de 2
    • Remove the cables from the cable guides.
  9. Lenovo ThinkPad T480 LCD Screen Replacement: étape 9, image 1 de 3 Lenovo ThinkPad T480 LCD Screen Replacement: étape 9, image 2 de 3 Lenovo ThinkPad T480 LCD Screen Replacement: étape 9, image 3 de 3
    • Using the Phillips #1 screwdriver, remove two 4.3 mm screws from each hinge (four total).
  10. Lenovo ThinkPad T480 LCD Screen Replacement: étape 10, image 1 de 3 Lenovo ThinkPad T480 LCD Screen Replacement: étape 10, image 2 de 3 Lenovo ThinkPad T480 LCD Screen Replacement: étape 10, image 3 de 3
    • Lift the keyboard bezel up and slide it out from the hinges to separate it from the LCD assembly.
    • In this image, all of the internal components were removed prior to this step so your device will look somewhat different.
  11. Lenovo ThinkPad T480 LCD Screen Replacement, LCD Bezel: étape 11, image 1 de 2 Lenovo ThinkPad T480 LCD Screen Replacement, LCD Bezel: étape 11, image 2 de 2
    • Use the metal spudger to create a space between the bezel and lid and carefully undo the clips around the perimeter of the bezel.
  12. Lenovo ThinkPad T480 LCD Screen Replacement: étape 12, image 1 de 2 Lenovo ThinkPad T480 LCD Screen Replacement: étape 12, image 2 de 2
    • Finish removing the bezel from the screen using the metal spudger and your hands.
    • The bottom edge of the bezel is not connected with clips but with adhesive. Take care as you remove it so you don't bend or break the bezel.
  13. Lenovo ThinkPad T480 LCD Screen Replacement, LCD Screen: étape 13, image 1 de 3 Lenovo ThinkPad T480 LCD Screen Replacement, LCD Screen: étape 13, image 2 de 3 Lenovo ThinkPad T480 LCD Screen Replacement, LCD Screen: étape 13, image 3 de 3
    • Remove the four 3.0 mm Phillips #1 screws from the four corners of the LCD screen.
    • Lift it up using the spudger and flip it over gently towards you.
    • The LCD screen is still connected by a connector cable so be sure not to yank or pull on the screen.
  14. Lenovo ThinkPad T480 LCD Screen Replacement: étape 14, image 1 de 2 Lenovo ThinkPad T480 LCD Screen Replacement: étape 14, image 2 de 2
    • Using the black nylon spudger, disconnect the display connector cable and remove the LCD screen.
3 autres ont terminé cette réparation.
Sarah Westberg
Membre depuis le 03/11/19
30 112 Réputation
71 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
121 membres
19 996 tutoriels rédigés
10 commentaires de tutoriel
For the screen replacement you really only need like 11 steps.
Step 1,2,9,10,12,35-40. All other steps are optional and it only took me 15 mins.
Batnert - Réponse
Hello i was wondering how much did the screen cost you to buy?
wau bruh -
If the internal battery is disabled why do you need to remove it?
Dan Matiesanu - Réponse
Hi Dan, if you disconnect the internal battery from the motherboard, (Step 12), you should be fine. We just want to make sure that there is no power to the system and the step to remove the battery is included as a precaution. Thanks!
Sarah Westberg -
@sarahw thank you but my question was more about why do you need to physically disconnect the battery if it is already disabled in BIOS?
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 81
30 derniers jours : 580
Total : 21,267
