Aller au contenu principal
Lenovo ThinkPad T480s Hall Sensor Replacement
Sarah Westberg
Sarah Westberg et un autre contributeur
Dernière mise à jour le April 3, 2024
30 minutes - 1 heure
Modérée
Use this guide to replace the Hall sensor in a Lenovo ThinkPad T480s laptop.
The Hall sensor is used in laptops that don’t have a mechanical latch. It can tell if your laptop is closed or not. If the Hall sensor is not working, it may not tell the system to turn off when the screen is closed. If your Hall sensor fails due to corrosion, cracks, or breakage, you may need to replace it. Prior to beginning the repair, check out the Lenovo Troubleshooting page.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Ce dont vous avez besoin
Pièces
Outils
  • Phillips #1 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Afficher plus…
  1. Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: étape 1, image 1 de 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: étape 1, image 2 de 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Hall Sensor Replacement: étape 2, image 1 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: étape 2, image 2 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: étape 2, image 3 de 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Hall Sensor Replacement: étape 3, image 1 de 2 Lenovo ThinkPad T480s Hall Sensor Replacement: étape 3, image 2 de 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: étape 4, image 1 de 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: étape 4, image 2 de 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Hall Sensor Replacement: étape 5, image 1 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: étape 5, image 2 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: étape 5, image 3 de 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: étape 6, image 1 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: étape 6, image 2 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: étape 6, image 3 de 3
    • Use a spudger to disconnect the cable from the Hall sensor.
  7. Lenovo ThinkPad T480s Hall Sensor Replacement: étape 7, image 1 de 2 Lenovo ThinkPad T480s Hall Sensor Replacement: étape 7, image 2 de 2
    • With the Phillips #1 screwdriver, remove one 3.1 mm screw from the sensor.
  8. Lenovo ThinkPad T480s Hall Sensor Replacement: étape 8, image 1 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: étape 8, image 2 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: étape 8, image 3 de 3
    • Remove the sensor from the system.
Sarah Westberg
Membre depuis le 03/11/19
29 943 Réputation
71 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
121 membres
19 827 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 21
30 derniers jours : 88
Total : 3,447
