Aller au contenu principal
Lenovo ThinkPad X395 Battery Replacement
Clay Eickemeyer
Clay Eickemeyer et 2 autres contributeurs
Dernière mise à jour le July 5, 2023
15 - 30 minutes
Modérée
This guide will demonstrate how to replace the battery in your Lenovo ThinkPad X395.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Lenovo ThinkPad X395 Battery Replacement, Loosen the back screws: étape 1, image 1 de 2 Lenovo ThinkPad X395 Battery Replacement, Loosen the back screws: étape 1, image 2 de 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These are captive screws—they won't come out after being loosened.
  2. Lenovo ThinkPad X395 Battery Replacement, Release the clips: étape 2, image 1 de 2 Lenovo ThinkPad X395 Battery Replacement, Release the clips: étape 2, image 2 de 2
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad X395 Battery Replacement: étape 3, image 1 de 2 Lenovo ThinkPad X395 Battery Replacement: étape 3, image 2 de 2
    • Insert the opening pick between the back cover and the device body at the other hinge corner.
    • Pry upward on the cover to release additional clips.
  4. Lenovo ThinkPad X395 Battery Replacement, Remove the back cover: étape 4, image 1 de 3 Lenovo ThinkPad X395 Battery Replacement, Remove the back cover: étape 4, image 2 de 3 Lenovo ThinkPad X395 Battery Replacement, Remove the back cover: étape 4, image 3 de 3
    • Lift and remove the cover up from the laptop, starting with the edge nearest to you.
    • Shift the cover side to side if the center clip feels stuck.
    • The cover will hinge open before completely separating from the rest of the laptop.
  5. Lenovo ThinkPad X395 Battery Replacement, Disconnect the battery cable: étape 5, image 1 de 2 Lenovo ThinkPad X395 Battery Replacement, Disconnect the battery cable: étape 5, image 2 de 2
    • Grab the battery pull-tab on the head of the connector.
    • Pull the connector out of its socket in the direction of the cable.
  6. Lenovo ThinkPad X395 Battery Replacement, Unfasten the battery: étape 6, image 1 de 1
    • Use your Phillips screwdriver to remove the four 5.3 mm-long screws securing the battery.
  7. Lenovo ThinkPad X395 Battery Replacement, Remove the battery: étape 7, image 1 de 2 Lenovo ThinkPad X395 Battery Replacement, Remove the battery: étape 7, image 2 de 2
    • Remove the battery from its recess.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad answers community for help.
Clay Eickemeyer
Membre depuis le 09/19/22
81 815 Réputation
455 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
9 membres
11 419 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 47
30 derniers jours : 155
Total : 4,072
