Aller au contenu principal
Lenovo ThinkPad x120e Keyboard Replacement
Jacob Fronzaglia
Jacob Fronzaglia et 3 autres contributeurs
Dernière mise à jour le May 7, 2024
7 - 15 minutes
Modérée
Before reading this guide on how to replace the keyboard for the Lenovo ThinkPad x120e, check the “Keyboard Not Responding” section on the device’s troubleshooting page to see if your issue can be fixed without replacement: Lenovo ThinkPad x120e Troubleshooting - iFixit
Reminder: make sure you turn off your laptop and remove any attached power cables before beginning..
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Lenovo ThinkPad x120e Keyboard Replacement, Battery: étape 1, image 1 de 2 Lenovo ThinkPad x120e Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Flip the laptop upside down and locate the battery latches under the battery.
    • Place your thumbs on both latches and push the latch inwards.
    • With your thumbs still on the latches, slide the battery out of the laptop.
    • To install a new battery, simply slide the battery back in the slot. Then, check if both battery latches are locked
  2. Lenovo ThinkPad x120e Keyboard Replacement, Back Cover: étape 2, image 1 de 3 Lenovo ThinkPad x120e Keyboard Replacement, Back Cover: étape 2, image 2 de 3 Lenovo ThinkPad x120e Keyboard Replacement, Back Cover: étape 2, image 3 de 3
    • Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
    • Remove the backplate carefully, making sure not to bend the cover.
  3. Lenovo ThinkPad x120e Keyboard Replacement, Keyboard: étape 3, image 1 de 2 Lenovo ThinkPad x120e Keyboard Replacement, Keyboard: étape 3, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the two 4 mm retaining screws located on the battery slot.
  4. Lenovo ThinkPad x120e Keyboard Replacement: étape 4, image 1 de 3 Lenovo ThinkPad x120e Keyboard Replacement: étape 4, image 2 de 3 Lenovo ThinkPad x120e Keyboard Replacement: étape 4, image 3 de 3
    • Flip the laptop back over, showing the keyboard.
    • Using an opening tool, pry open the keyboard starting from the top left. Work your way around until you are able to loosely lift the keyboard.
    • You should see two ribbon wires located beneath the keyboard once you are done.
  5. Lenovo ThinkPad x120e Keyboard Replacement: étape 5, image 1 de 2 Lenovo ThinkPad x120e Keyboard Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • Pull on the black tabs above both ribbon wires using tweezers upwards.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Remove both ribbon wires.
    • Remove the keyboard from the laptop.
Jacob Fronzaglia
Membre depuis le 10/25/21
787 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 Membre de l'équipe UMass Dartmouth, Team 3-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 20
Total : 471
